Scraping my cx racing intercooler. What's next?
I wouldn't waste my money on treadstone, too many guys who push their setups hard report really high iats. My custom garrett core was $800 shipped all the way across the US. Chiseled Performance is the ****, you draw up any mounts, bosses or whatever and he will do it. Nothing compares to Garrett fin density.
Treadstone offer what they call an R rated core which I guess is trying to be a Garrett...but probably wont be.
Again, all depends how much heat is an issue, or flow is an issue, or both and your budget, size restraints etc.
Shearer is another well trusted fabricator etc who could build a complete unit, probably not at the cheaper end though
http://shearerfabrications.com/
I always wondered if the actual cores were diff from a cheap core to an expensive one-is the design that much diff, to promote good airflow plus better cooling.
A few years ago I had a Procharger sheetmetal IC'er I used on an LS with a blowthru carb, as I remember it was like 1 psi loss at around 12 lbs. I remember doing some testing on another car, off brand IC'er, temps out of the Procharger were 330 degs, knocked down to 190 @ 18 psi after the IC'er.
In 40 deg temps last year, I made a couple passes with my turbo Buick, Treadstone 25 IC'er, IAT's were in the 140-150 range. I never checked psi loss, would have liked to. I kind of wonder if you have a large pressure drop, rem. the IC and reducing the boost to the same level you were getting the temps would drop just based on the comp. having to comp. less to get that boost. I would guess a turbo makes more heat than a Procharger, at least on low boost, might even out on higher boost. OK, to much coffee already, lol
I know a guy in glens falls , he did my procharger race valve and flange . He does you buy the core and he makes the ends all the time . So if you want to go that route.
I did back to back testing a few years ago with treadstone vs a garret core. The treadstone was junk compared to the garrett.
Heres the data.
https://ls1tech.com/forums/forced-in...l#post17843058
Heres the data.
#32
Welp. The 1200hp treadstone is on backorder for 2+ months. Now I'm looking into their 1300hp one ( 22x12x6) that I've seen as low as $579. My main concern is room. I don't really have many options when it comes to re routing my turbo kit so it's gotta be somewhat close to what I had
#33
Heres the data.
Heres the data.
#35
#40
