Cranking compression JFR218 cam in a 5.3
To anyone out there, what are your results? I️ see around 165 psi, throttle open with a good charge on the battery. The cam was degreed when installed and put in at 108 centerline. I’m used to seeing 185 psi+ so this just seems low to me. My 5.3 is roughly 9.5:1 also. Let me know.
Strange situation, I run a small battery (like lawn mower sized) and it did not like cranking my 11.1 LS1 over. When i swapped to a 243 headed L33 with an isky turbo grind, it spins it over like its on speed or something. After posing the question to a few, maybe its the turbo cams events that help the engine light off easier? I dunno.
