Going to run a mircosquit what do i do with the IAC
Thanks
Dennis
The one from EFIsource is an open loop IAC controller. It adjusts the stepper based on coolant temps and not much else. It also takes up all of your inputs/outputs from microsquirt.
I have a microsquirt add-on module made that does closed loop IAC control but I'll still be testing it through spring at least.
