the right turbos
Old Jun 26, 2018 | 11:00 AM
steves86ta's Avatar
Default the right turbos
hi all,
I admittedly know absolutely nothing about turbos. I am reading and reading and reading and trying my best to learn as much as possible.
I am putting together a parts list and starting to order parts for a turbo build. (im a N/A or nitrous guy)
I have a jet boat, and want to switch from my current high compression/Nitrous assisted 5.3 setup to a lower compression/turbo setup.
I am planning on putting together a forged 6.0 or maybe a 408. But lets lean towards the side of 6.0.
I would like to be able to make 1000+ hp, but I do not have a set number This will be a blowthrough setup with a CSU Carb. (most likely their dual needle/seat carb)
I am looking at a couple of turbos, and the way i understand their sizing/exhaust husing sizes.
One is a Borg Warner S366 with a .88 A/R housing.
The other is a T76 (cx racing) with a .68 A.R housing.
Any other recommendations? Im looking for somewhat budget friendly.
I would like it to spool relatively quick, Will be running twins.
for those that dont know, a jet pump loads an engine down like a Single Speed powerglide with a really loose convertor.
I dont need instant spool, but a second or two to a decent amount of boost would be preferred
Thank you for any info.
steve
Old Jun 26, 2018 | 12:00 PM
JoeNova's Avatar
Restricted User
The S366 in twins would be much better than the T76 turbos from CX.
Old Jun 26, 2018 | 12:05 PM
steves86ta's Avatar
Thank you for the information
Old Jun 26, 2018 | 12:15 PM
JoeNova's Avatar
Restricted User
If you want a cheap turbo gamble, check out Rev9 turbos. They offer tons of them in the 62-72 range with appropriate sized turbines in T3 and T4. They also offer them in billet for $300 a pop.
I'm just not 100% on their durability. I have a pair of 6662 billet T4 turbos from them that I scored for $550/pair but haven't finished the car to try them out.
Old Jun 26, 2018 | 12:24 PM
steves86ta's Avatar
I found a T72 with a .81 A/R on CX Racing's website.
The little i know seems like htis would be a good size. No?
https://www.cxracing.com/TRB-T72-P81-RR
Old Jun 26, 2018 | 12:54 PM
Black89Z51's Avatar
Any particular reason you want to go with twins instead of a larger single to make thing simpler?
Old Jun 26, 2018 | 01:08 PM
steves86ta's Avatar
Twins look better... Purely aesthetic reasons
However would a single be better? I figured smaller twins would spool faster.
Im an open book, ill take any suggestions
Old Jun 26, 2018 | 01:12 PM
JoeNova's Avatar
Restricted User
Its largely a fitment/price/preference thing. Both can be made to spool equally well or make big numbers.
Old Jun 26, 2018 | 02:04 PM
steves86ta's Avatar
Well, im not worried about fitment.
Is it cheaper to go with a larger single?
What size/Ar should i be looking for in the realm of a single?
Old Jun 26, 2018 | 02:11 PM
fif_gen_powa's Avatar
Can be cheaper yes, one turbo one wastegate, gonna need something fairly big to make a clean 1000hp on a single 80+mm budget would be a s480 t6 with the large turbine
Old Jun 26, 2018 | 02:20 PM
badass68's Avatar
FYI, carbureted turbo setups never last. Too much to go wrong.
Old Jun 26, 2018 | 02:24 PM
JoeNova's Avatar
Restricted User
Single billet S480 will do the trick. If you want slightly faster spool, spring for the 1.25 T4 housing and keep the large wheel.
A/R itself means very little and doesn't determine overall size of the turbo housings.
Old Jun 26, 2018 | 03:06 PM
steves86ta's Avatar
Why do you say that?
Old Jun 26, 2018 | 03:09 PM
steves86ta's Avatar
Like this one?
https://www.ebay.com/itm/Borg-Warner...IAAOSw07VagON8
Old Jun 26, 2018 | 03:11 PM
steves86ta's Avatar
or this?
https://www.ebay.com/itm/BorgWarner-...AAAOSwd4tT~iqC
Old Jun 27, 2018 | 07:20 AM
Black89Z51's Avatar
Originally Posted by steves86ta
This one. The 2nd one you listed is a T6 housing and will give you a slightly slower spool.
Old Jun 27, 2018 | 07:49 AM
The T6 will also make more power, more efficiently and imo is more suited to a 6.0l engine size.
Old Jun 27, 2018 | 07:58 AM
JoeNova's Avatar
Restricted User
Not always. It'll only make more power if the T4 is a restriction to begin with. 1000 HP has been done time and time again on the 1.10 and 1.25 A/R T4 housings with even the 87mm wheel.
Old Jun 27, 2018 | 08:11 AM
Dimeomboost's Avatar
There's a thread in here right now where a guy with twin borg warner s366 turbo on a 408 made like 1250 to the wheels. I have a 6.0 twin box stock s366s full weight 2001 mustang that runs 5s in the 1/8 mile. On a jet boat twins is the Only way to go it looks clean and symmetrical as well as ease of install 2 headers 2 turbos no crossover no fabrication work to mess with. Plus u can pull the header off and leave the turbo mounted to service any part of the motor.
Old Jun 27, 2018 | 10:52 AM
steves86ta's Avatar
Thats a good point.
As far as mounting the turbos, with the ebay turbo headers, are they strong enough to hold the turbo(s)? Or should i make some braces?
