Anybody have a TTI race kit??
Old Jul 3, 2018 | 09:46 AM
Dark SS's Avatar
Default Anybody have a TTI race kit??
I picked up what I think is a Turbo Technologies Inc. race kit. It has an A2W intercooler and a 76mm T4 turbo. TTI doesn't have any pictures of this kit on their website any more. I know it's an older kit but I believe it's the same one Mightymouse started out with. I looking to get a general idea on how it goes together. TIA.
Old Jul 12, 2018 | 08:15 AM
Dark SS's Avatar
No one huh?
Old Jul 12, 2018 | 08:49 AM
ddnspider's Avatar
Man thats a blast from the past. I assume you searched on here? Everyone probably used photobucket before they screwed us and we lost our picture links.
Old Jul 13, 2018 | 01:56 PM
Dark SS's Avatar
That's what I've noticed. Seems they still sell it but in the world of Huron Speed and On3 nobody buys them.
Old Jul 14, 2018 | 10:30 AM
NicD's Avatar
7 Second Club
TTi was one of the first companies to produce turbo kits for these cars but others have come out since then. I had the TTi race kit on my Camaro which I still have pictures of on my website. I made a few modifications over the years but it is still a nice kit.
Old Jul 17, 2018 | 02:55 PM
Dark SS's Avatar
Awesome, thanks. I actually stumbled on your page when searching here for any info on the kit. What size turbo and motor were you running?
Old Jul 17, 2018 | 05:01 PM
NicD's Avatar
7 Second Club
I was running an old school 76GTS with a stock cubic inch LS1 with good rods/pistons, mild turbo cam and old 1st gen AFR 225s.
Old Jul 18, 2018 | 07:50 AM
Dark SS's Avatar
Awesome, I'm not to far off. I have a 76mm Turbonetics and a stock 5.3 that I may through a set of pistons and rods in. E85 flexfuel system, TH400, 9" with a 3.25 gear. I'm hoping for 9.50's.
Old Jul 23, 2018 | 10:54 PM
Drewstein's Avatar
He ran into the 8s with his setup but I think your gear isn't going to be enough to get to your goal when you're also limited on power with the stock bottom end.
That's not a bad kit though, with a strong bottom end your car should be where his was.
Old Jul 25, 2018 | 01:47 PM
Dark SS's Avatar
3.25 should be fine with 750-800 wheel I would think. I have not bought the gear yet but I won't go higher than a 3.45 with a 400. I'm hoping the bottom end with live a happier life on E85, a forged bottom is on the horizon along with a bigger T4 turbo.
Old Jul 25, 2018 | 11:20 PM
Drewstein's Avatar
I run a 3.25 and it took a good bit of boost to hit 9.5s with a 400. I think 3.45 would be better since you'll be down on rwhp with that motor. Maybe Nic will chime in with the gear he was running with his setup.
Old Jul 26, 2018 | 07:54 AM
Photochop's Avatar
With the right converter the 3.25 will be fine.
Old Jul 26, 2018 | 10:27 AM
NicD's Avatar
7 Second Club
Yeah gearing depends on the converter and how loose/tight it is for both the launch and slip up top. I was running 3.42 rear gears and ran both 28" and 30" tall rear tires and would cross the traps around 6400-6600 rpms and would trap low-mid 150s. Had a custom Neal Chance converter that was relatively tight.
