Boost build for the street - advice please
I know stock LS1 turbos get some serious power with bolt-on gear only but I want it to last too, so I am happy to upgrade what is needed but an LSX block and luxuries like that are way beyond the budget.
My personal goal is to run anything in the 9 second zone (a boosted LS should easily do that) and running an 8 would be amazing.
I am open to ideas, feedback, anything you guys want to share, so fire away.
Cheers
But with a strongly built trans, and engine etc...9's should be easy. 8's perhaps less so, but comfortable 9's should not be a problem. If you intend on using 98RON only, then I would definitely keep the CR to around 9.0:1, no higher.
If you may add methanol injection or similar, then you could bump that a bit higher...but TBH, I'd still err on the safe side. There's negligible loss for big margins on safety vs pushing higher CR's
Cant comment on wall thickness of the block though
https://ls1tech.com/forums/forced-in...ion-wagon.html
https://www.ls1gto.com/forums/showthread.php?t=837586
The only limitation will be a CR that's too high and you become knock limited.
9.0:1 CR is in no way whatsoever a limitation to making power, it will help make the power safely.
IMO “building” and engine doesn’t mean it will be more reliable most of the time. Not only are you at the mercy of a machine shop to get things right... (rarely happens for me) but fact is at these power levels things go wrong, period. Built engine or not, something will break eventually. So why have a mint tied up in the long block? Personally I like to keep the engine long block bone stock. Add a cam/springs and spend the big money on the driveline, turbo system, fuel system, and ECU. When every things “right” the Stock short blocks are damn tough. Buy a spare long block (or 2) and have it ready to drop in. Design the turbo kit in a way that makes it friendly to remove. Then plop in new engines as necessary. Engines are the cheap part and should be treated as disposable IMO. Unless you plan to run a nice aftermarket block to match an aftermarket rotating assy you aren’t doing yourself much of a favor. The good rotating assembly will just wiggle around in an OEM block at big load/power levels.
I’ve run basically “cam only” GEN4 4.8, 5.3, and 6.0 in my 3100lb car with very street friendly gearing. All have easy 8 sec potential. The 6.0 is the best suited IMO as it works best with the least amount of RPM on a factory intake TB etc. The 5.3 and especially the 4.8 need to be revved higher. So aftermarket top ends, intakes, etc suit them better. I also don’t like the shorter gearing needed to keep the little motors happy on a street car. That can be offset with the OD 4l80e but again you are adding big expense there.
Matt Happel’s truck is a good example. 3850ish lb race weight going high 9’s around 900whp. That’s cutting a lot of corners with low reliability and lacking all the comfort amenities. Add more weight, ride comfort and reliability into that build and the budget would need to go up substantially.
https://ls1tech.com/forums/forced-in...e-3850lbs.html
Whilst I do also use water/meth, I'd be pretty sure I could still run 9's on pump alone too.....but I never built mine to specifically run pump only for that sort of use ( although most of the time I do ) so it's not a fair comparison as to how far it could be pushed when built with that in mind.
If mine was an auto....it seems most can knock almost a full second off their times vs manual. Although I doubt mine would drop that far
Last time I was at the strip a couple of years ago....before the ******* clutch slipped ( which is another whole story ), I did 10 flat at 152 with a poor 60ft of 1.76s
Next run was a little better until 3rd gear then the clutch just slipped like ****. If the 60ft dropped to similar to what I'd done 10 years ago circa 1.5s, the time should very comfortably be mid 9's
@forcefed - Those are great points but we don't have any light weight cars here that can take a V8 easily, we have some old 70's cars that are small enough but that's not what I want to drive and I'm not looking at building a trailer sailor or the equation would be very different (super light tube car with a turbo LS would be an exciting prospect). I know of a guy with a single turbo on a stocker 5.7 (common LS over here) and he has run 10.1 but yes he has broken a few shorts on the way too.
What car are you using at 3100lb?
I'm not really sure which way to go with this build, it's not our main transport so I don't expect it to be smooth and pull 30+ mpg
@stevieturbo - Clutch slipping 152 mph run .... You sir should be aiming at 8's with an auto and full respect to a mid 9 with a manual.
But there is no reason you cannot achieve the goals and be very smooth etc. 30+mpg is dreaming though lol
