BMR Turbo K users
Old Nov 11, 2018 | 06:52 PM
SCott5's Avatar
Default BMR Turbo K users
Hey guys. Mocking up my new T4 AC kit and looking at k members. I was going to run the BMR turbo k but BMR says do not use solid mounts with it and the HSP doesn't have a flex joint so not sure if it will move enough with poly mounts to cause issues or possibly heat from the downpipe cause issues? Anyone use solids and could shed some light which ones will work?
Old Nov 11, 2018 | 07:14 PM
007FJ's Avatar
I can't help you but I had to sell my UMI and get the BMR per Jon at Huron. I have a few pictures on that sway bar question thread that may or may not help you but worth a minute of your time to see.
Old Nov 11, 2018 | 07:19 PM
007FJ's Avatar
https://ls1tech.com/forums/forced-in...r-fitment.html
https://ls1tech.com/forums/forced-in...-sway-bar.html
Not as helpful as I hoped but if you don't get an answer PM me a number and I'll take or dig through my picture collection.
Old Nov 13, 2018 | 05:47 PM
SCott5's Avatar
did you use solid mounts?
Old Nov 13, 2018 | 06:11 PM
007FJ's Avatar
No Energy Suspension
Old Nov 14, 2018 | 06:37 PM
SCott5's Avatar
You have the same kit? Downpipe out the back? Any issues with the poly? How long have you had the kit on?
Old Nov 15, 2018 | 11:10 AM
Black_Sunshine_99's Avatar
I know its not the V3 kit since I'm using the V1 kit but I've had poly mounts in mine for four years without issue and the down pipe runs right past the mount along with the exhaust manifold.
The down pipe is wrapped but the manifold is not.
The car gets regularly street beaten as well so I'd feel totally comfortable recommending a poly mount with HSP's kits.
Old Nov 15, 2018 | 06:19 PM
SCott5's Avatar
Thank you! That's the type of feedback I'm looking for
Old Nov 16, 2018 | 09:42 PM
007FJ's Avatar
Default Climbed under there today V3 AC Kit
