XS power Top Mount T4 Manifold setup/review
Ive searched and searched and couldn't find anything from anyone on this forum or any other, Has anyone used these before? I just recently got a set in the mail and will be test fitting them on my 75 Dodge Dart Swinger, and since i haven't seen anyone share anything i figured i would do a write/review of them. Here are a few initial pictures and first impressions from them.
They came very well packaged, welds look clean and sharp, overall initial quality looks to be pretty good in my opinion.
They even took the time to smooth out the welds on the runners at the flanges so they aren't like some of the cheaper up and forward facing manifolds found on ebay.
Driver side manifold
passenger side manifold, t4 top mount flange and 44mm waste gate flange welded.
as soon as i get these mounted ill get pictures posted up.
here is a link in case anyone was wanting to look into the set.
http://www.ebay.com/itm/For-LS1-LS2-...5.c10#viTabs_0
Here are the follow up pictures of how the passenger side mounted up on my dart. It mounts the turbo a little too high for my hood, but from my observation these would be perfect for truck setups and possibly some others. I was unable to get the driver side to clear due to steering shaft interference. But again, would work great on other Chevy products that don't have Mopar with and LS1 clearance issues like me.
I've run their manifolds in the past on my Eclipse Gsx/talon tsi's ranging from stock turbos to precision 6262's all upwards of 32psi and I've never had an issue with their products. That's why I was trying to run them again.
Man that's cheap... all it needs is some black wrap to make it pretty enough for my C10 swap.
How tight is the cross over routing to the block/tranny? What tranny were you planning to run?
Looks crazy high in your pic but how much over the top of a truck mani do you think it would sit
Did you relo the coils and do the spark wire clear?
I had the truck mani on my motor before and it just cleared the hood. So it would probably be between an inch or 2 higher. But that's a rough estimate.
also here is the direction of the downward facing portion of the passenger side manifold. Like I said, la swap in mopars doesnt leave much options. But this could easily have been straitened out to work on the passenger side, if only the driver side would have cleared.
Here is two updated pictures of one on a truck motor with the truck Intake. I know someone asked about the height in relation to the truck intake. This should give you and idea. More pics to follow of the other side and then actually in the truck.
