Should it be clattering at this low boost?
Old Nov 30, 2018 | 09:42 PM
  #121
SLOW SEDAN's Avatar
Originally Posted by Game ova
Slow sedan, bring the C6 to beech bend in the spring, bring a bag with you as well.
To race you? I may as well bring an empty bag so I can fill it up. You need to gain 20MPH over the winter and before you start with the excuses its full weight lol
Man, I keep jacking around with you, I might get halfway interested in making the car fast. Lemme guess, ther c6 runs 9 teens letting off at the 60ft?
Yup, ***** slow as hell. Both cars run solid 9 teen 1/8th miles! Its hit or miss if I can beat a Prius on any given day.
Old Dec 1, 2018 | 05:04 AM
  #122
Game ova's Avatar
Old Dec 1, 2018 | 09:28 AM
  #123
Kfxguy's Avatar
Since this thread is so far off track (I don’t care,...think it’s funny) I might as well ask. What do you guys think of this boost strategy and my theory. Say I leave the line on a couple lbs. ramp it up to say 6 at the top of first gear. Second gear gets ramped to 8-10lbsand then third goes up to 12-13lbs. My theory is I’m only running high boost for maybe 3 seconds at at time. So that should be safer?
Old Dec 1, 2018 | 09:43 AM
  #124
truckdoug's Avatar
Don't you have snow to plow with that front bumper??
it's off plowing snow right now I think. sold it to a fella from the great white north
  #125
ddnspider's Avatar
It'll help IAT's and probably help with combustion temps so it can't hurt. Might help with traction too.
Old Dec 1, 2018 | 10:25 AM
  #126
Kfxguy's Avatar
i just know supposedly they don’t last long at 12lbs or above. So I was thinking the limited time at that pressure may help keep it together until the other motor is done. Haven’t started even collecting parts for it yet so that may be a while lol.
What do do you guys think about getting a triple disc converter and locking it in third gear? I figured it would pick up mph. Right now I have just a regular yank power adder series 3400 so I can’t lock it. Wonder if it would kill the converter if I did it once or twice at the track for a hero pass? Then that would let me know if it would be worth locking up. I’d get a baseline mph first.
Old Dec 1, 2018 | 10:31 AM
  #127
ddnspider's Avatar
Stock trans? I wouldn't lock it. Not worth the gains.
Old Dec 1, 2018 | 10:37 AM
  #128
Kfxguy's Avatar
nah it’s a built trans. Got good **** in it. That’s why it’s holding like it is. I build transmissions, bern doing it for about 20 years. Mainly 4l60’s. I’ve had pretty good luck getting them to hold under 750hp in a 4000lb car. It’s the converter I’m concerned with. I break or burn the trans, I’ll just fix it. No worries there.
Old Dec 1, 2018 | 10:41 AM
  #129
ddnspider's Avatar
I have a Yank3600 in my car and had no issues with it. I still wouldnt lock it up unless youre going for max effort.
Old Dec 1, 2018 | 10:46 AM
  #130
BCNUL8R's Avatar
Heck ya...I wouldn't be worried about it above 12 psi if the tune is good and you are using meth. Sure all the time beating on it will not last forever, but just turning it up at the track it would probably last a long time if the tune is good with some meth. I'm kind of in the same boat as you, but I decided I'll just buy a short block when I need it. The wait time on them is usually within 6 weeks for common builds so not a big deal for a car that is just a toy.
Old Dec 1, 2018 | 11:55 AM
  #131
truckdoug's Avatar
lol you know when the 60e guy says it's not a good idea, it's actually a ******* horrible idea
Old Dec 1, 2018 | 11:58 AM
  #132
98CayenneT/A's Avatar
4l60e guy here also....
I wouldn't lock a single disk converter in a 4l80e either at that power level. Has nothing to do with transmission type, just converter.
Old Dec 1, 2018 | 01:14 PM
  #133
47ford's Avatar
From my understanding there is no reason to lock the converter unless you are blowing through it..... circle d told me my triple disc is good to around 800 unlocked and 1000 locked.... said I would never hurt it locking it up under power... actually dared me to try and hurt it lol.... so in short if you are starting to blow through the converter at high power levels then lock it up and it eliminates slip?
Old Dec 1, 2018 | 01:23 PM
  #134
Kfxguy's Avatar
yea I won’t be beating on it with 12lbs. No meth yet. But that’s planned. Depends on how much time before the track opens again. I picked up an aluminum 5.3 already for $500 but it doesn’t have the good rods. My plans are to upgrade this one while I’m running the ls1 but try to make it last. Then when the 5.3 is done I’ll put it in the car and let it eat. Then if the ls1 is rebuildable (if I don’t hurt it) then I’ll build a 383 out of it. Never ends does it?
Old Dec 1, 2018 | 01:32 PM
  #135
Kfxguy's Avatar
supposed to make good mph gains on a turbo car. Heck my 3rd gen picked up mph. It wasn’t as fast as this car is. You could feel it pull harder when it locked, felt like warp speed lol. Not really but it felt like it pulled much harder. That car was 3400 with me in it. Made 447 and 479tq old school 383 solid roller, trick flow r’s ported by me and a TPIS Mini ram and haltech computer. Think it trapped 119-120 then locked 122-124
Old Dec 1, 2018 | 01:49 PM
  #136
ddnspider's Avatar
I may be a little crazy but I'm not stupid!
Old Dec 1, 2018 | 01:54 PM
  #137
MY_2K_Z's Avatar
Ya locking the converter on the big end feels like you just hit another 100shot of nitrous with the boost. It's will really pull when it locks.
Old Dec 1, 2018 | 09:46 PM
  #138
truckdoug's Avatar
I cant remember if 60e's can log TCC slip. I know 80e's can.
Old Dec 2, 2018 | 01:49 AM
  #139
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
1/4 times are all about the little details. If you want to get better times, you abuse the **** out of your drivetrain. This is simple fact. If you want your components to last a long time, then don't. The GTO is a pretty heavy ride, and if you build transmissions you understand what that means. Also, when your axle stubs twist, they are a nightmare to get out. As a side note, if one of them breaks, the resulting one wheel peel will burn out your factory limited slip clutches in less than a second. Then again, I have a t56 car, so my drivetrain was doomed from the start.
Old Dec 2, 2018 | 06:51 AM
  #140
ddnspider's Avatar
Pretty sure you can.
