Opinions on my LS1/TVS1900 Setup
Old Jan 25, 2019 | 09:20 AM
stng_96's Avatar
Default Opinions on my LS1/TVS1900 Setup
I am adding a TVS1900 blower to my LS swapped miata. Car has been fun for a few years but I've got the itch again and I have finally located a GTO TVS1900 to install, should be here early next week.
My current setup:
2002 LS1/T56
stock engine
stock 241's
TSP 228R
1-3/4 Kooks LT's into a straight dual custom 2.5 system with borla mufflers
No EGR/Evap/Emissions of any kind
Made 405 at wheels on Dynojet when tuned
The few questions I have:
-Obviously boost levels vary wildly depending on your setup, but anyone want to take a guess at what boost number I'll be in with the above setup? Likely will run 3.0 front and 1:1 rear cogs. I am wanting to be in the 8-10psi range, and I believe I'll be at or below that.
-Think it will be worth it to change the cam out? I have enjoyed everything about that 228r (228/228, .588/.588, 112) and at 4 degrees overlap I don't think it will perform terribly. I know a cam with a longer exhaust stroke will be better, but for the additional trouble I'm just not sure its worth it.
Old Jan 25, 2019 | 11:30 AM
ddnspider's Avatar
Id leave the cam alone. You should be able to make 10 psi with that setup since they're stock heads. You could consider 317's if you wanted to drop the compression a bit.
Old Jan 25, 2019 | 12:16 PM
stng_96's Avatar
I'm leaning toward leaving the cam alone too. I'm not overly concerned about the compression, if I need to I'll spray some meth but I'm thinking this setup I can just stay on pump gas.
Old Jan 29, 2019 | 08:25 AM
stng_96's Avatar
220 views and 1 reply? I guess with LS3 parts out there, there just aren't as many ls1 guys doing this kind of thing anymore. Blower gets here today, can't wait to get her on there.
Old Jan 29, 2019 | 09:28 AM
hellbents-10's Avatar
It will run pretty good with that cam in there. Also the overlap will help things with pump gas too. Run it and have fun.
Old Jan 29, 2019 | 09:40 AM
Gav's Avatar
Gav
Hi,
please could you do me a favour whilst you are installing it? Height of tvs1900 manifold top from valley plate?
btw, did you get it new?
regards
gav
Old Jan 29, 2019 | 09:45 AM
stng_96's Avatar
Originally Posted by Gav
Hi,
regards
gav
Sure, only because it would've really helped me if I could have had that info when I was buying! I am going off best interpretation against other engine parts that it will fit my application. I may end up having a blower pulley out of my hood!
No I did not buy it new, honest to god I couldn't stomach the 7k or so for a kit that wasn't actually set up for my application. I found it used and it took about a month to get the seller to sell it to me because it was part of a package deal with a GTO, but he finally did. $4500 to my door, Teflon coated rotors, 8 rib pulley setup, ported snout for 102TB. Should make my little miata scoot!
Old Jan 29, 2019 | 09:47 AM
Gav's Avatar
Gav
Nice....no deals like that in UK!
regards
gav
Old Jan 29, 2019 | 11:09 AM
$$$$'s Avatar
Should be a fun set up! Curious to see results.
