Oil cooler before turbo?
Yes it would be easy to plumb, maybe help cool the turbo and oil down a little. Maybe the oil being dumped back into the engine would be cooler? Probably just wasting my time?
1) mostly on import sites, the replies from the forum members were dumb and not informative
2) no one posted anything but speculation
3) it’s still probably pointless the more I think about it lol. Say my oil temp in the engine is 200f. The cooler cools it to say 170. It hits the hot housing of the turbo, it can’t compare to cool it down when hot exhaust housing is bolted to it.
Which makes me wonder why in the heck exhaust housings arent separated/insulated from center section and turbine.
If you have an oil temp sensor in the pan and that oil is getting to hot, that would be the time for a cooler i think.
I wouldn't worry about an oil cooler unless the oil temp is creeping over 250*F periodically. If you need one, I wouldn't put it on the turbo feed nor drain. Use a sandwich plate off the oil filter housing with a thermostat. You can also consider a remote mounted oil filter with a larger Ford sized 3/4-16 threaded filter. You get better oil flow through the filter and a slight cooling effect since the filter isn't sandwiched between a hot engine and even hotter header.
With the turbo, I also recommend using an oil formulated with a decent bit of PAO for high temperature stability and shear stability. Mobil 1 Extended Performance 5w-30 would be an entry level for this category with Red Line HP 5w-30 and Driven LS30 5w-30 topping that list. I use LS30 in my 5.3L with a Fram Ultra XG9837 filter changed every 10k miles.
With the turbo and rpm, I'd more concerned about oil aeration than temperature.
Hope this helps.
After making back to back pulls my idle pressure takes a hit, I flip the fan switch and within a few minutes my pressure comes back up and is more stable.
