Black WS6 with single Holset +E85
Old Jul 31, 2019 | 08:48 AM
Juuso's Avatar
Default Black WS6 with single Holset +E85
Heres my little build. Been owning this since 2012, bought it completely stock.
Its currently SBE ls1 + t56, with 228r cam, ported heads, dual valve springs, chromo pushrods, double timing chain, mellings oil pump and so on. With holset hx55, running about 8 pounds of boost now. Its been boosted about 15k miles now, maybe more.
I have no idea how much power it have, i tune it by myself with hp tuners, so no dyno pulls, but it goes like a maniac. Smoking 315 tires still at 3th gear, if the road is even slightly cold, it wants to go sideways at 4th. First it was fun, now a little scary, so i started to build 9 inch rear, so i can use some grippier tires (stock 10 bolt with 4.11). I'll make it myself from laser cuts, will be posting pics.
I will post more pics soon.
Old Aug 1, 2019 | 12:23 AM
TPIZ92's Avatar
And the turbo is holset hx55.
Nice looking car man let's see some more pics
Old Aug 1, 2019 | 02:31 AM
Juuso's Avatar
Thanks.
I'm having a problem with the pics, every time i try to post a pic, it needs approval from admin, because my low post count (i'm a new member).
Btw, i have seen lots of speculation about these holset turbos in ls engines, and for my experience i love it. This is (for now at least) 100% street car, so i have no idea how will it work at track car. But at street, it is brilliant. Makes LOTS of torque and spools quickly and will not run out of breath even at 12psi @6000rpm. But if it does someday, i'll just buy a bigger one. Very very nice and fun thing to drive.
Old Aug 1, 2019 | 12:30 PM
bnorth's Avatar
I'd love to see some more pics of your setup, nice car. I've boosted lots of cars with Holsets over the years and had a few cummins trucks so I have a soft spot for them.
Old Aug 1, 2019 | 01:09 PM
Reckless's Avatar
Super Moderator
Good looking car!
Old Aug 1, 2019 | 01:10 PM
soloman369's Avatar
LMK when you want a better turbo I got the hook up for you
Old Aug 2, 2019 | 03:17 AM
Juuso's Avatar
Thanks. I will try again as soon as i get home. Yes, me too. They are dirt cheap, reliable and the spooling sound is LOUD. I have full exhaust, so it sounds like a jet plane ready to takeoff.
Originally Posted by Reckless
Good looking car!
Thanks man.
Old Aug 2, 2019 | 03:20 AM
Juuso's Avatar
I'll keep that in mind.
Old Aug 2, 2019 | 04:42 AM
Jimbo1367's Avatar
  • Great looking car. I’m in for more pics
  • thanks
  • Jimbo
Old Aug 2, 2019 | 08:09 AM
Juuso's Avatar
Finally going to pull the engine out this winter. I'm thinking tubular front end, so i can gain more room, its pretty tight package.
Old Aug 2, 2019 | 08:17 AM
Juuso's Avatar
Made clear lenses to drl other day, came out pretty good.
Old Aug 2, 2019 | 08:29 AM
Juuso's Avatar
Exhaust tips i made couple years ago. 2x3" pipe, not the lightest i must say, but fills the bumper.
I have lots of pics from the build process somewhere, needs to start looking.
Old Aug 2, 2019 | 08:31 AM
ddnspider's Avatar
Holy smokes that's a tight fit. Interesting your cold side comes up from the pass side and not the driver.
Old Aug 2, 2019 | 08:54 AM
Juuso's Avatar
I know..
I've relocated the battery in trunk, so theres lots of space for the piping.
Old Aug 2, 2019 | 09:10 AM
Juuso's Avatar
2.5" crossover pipe with 50mm wastegate.
Old Aug 2, 2019 | 09:27 AM
Juuso's Avatar
Trap door for fuel pumps (dual walbro 255) and lights, so i can see when the secondary pump kicks in (right at 4psi).
Old Aug 7, 2019 | 10:55 AM
Juuso's Avatar
Starting this project.
Old Aug 7, 2019 | 10:57 AM
Juuso's Avatar
Old Aug 7, 2019 | 12:49 PM
Juuso's Avatar
If anyone has 9 inch third member (that sounds wrong) lying around and wants to help me with one measurement, i would be grateful. Measure from front plate to center of axle tube is 1.700 inch, im i right?
Old Oct 20, 2019 | 07:26 AM
Juuso's Avatar
Updates. I pulled the engine. Now its time to clean up and paint engine bay, tube bumper support, wiremods, fusebox mods and all the tricks in the book.
