Turbine wheel sizing
Old Sep 19, 2019 | 10:52 PM
sewerpickle's Avatar
Default Turbine wheel sizing
SBE 5.3, LJMS stage2 turbo cam, LS6 intake, #210 injectors, E85, with a BTE Glide. #3,100 car
S475 T6, 1.32 a/r 96/88 wheel. Is this turbine wheel too large for the combo?
Old Sep 20, 2019 | 06:32 AM
svslow's Avatar
Nope.
Old Sep 20, 2019 | 08:09 AM
Mavn's Avatar
"I MAID THEESE"
Nope just make sure your converter is loose enough yo lwt it spool
Old Sep 20, 2019 | 09:47 AM
DBRODS's Avatar
No the compressor wheel is too small.
Old Sep 20, 2019 | 10:06 AM
Probably needs to be an S480-96/88?
Old Sep 20, 2019 | 11:02 AM
truckdoug's Avatar
yeah a billet s480 with the big turbine is a killer turbo if you have the fuel
Old Sep 20, 2019 | 11:34 AM
DBRODS's Avatar
Atleast a 80mm, even a 84mm will work great.
Old Sep 20, 2019 | 11:44 AM
SLOW SEDAN's Avatar
Turbine wheel isn't large at all. What's the MPH goal? Cast 74 has been 150+, billet 76 has gone 160+ well above that weight.
Old Sep 20, 2019 | 11:51 AM
Goal is to put a #3,100 car into the low 9's high 8's. I really don't care how is spools on the street.
Old Sep 20, 2019 | 11:54 AM
ls3fox's Avatar
7 Second Club
I’ve been 8.4@159 in a 3150lb foxbody with a cast wheel 75
Old Sep 20, 2019 | 11:55 AM
SLOW SEDAN's Avatar
Well a billet 76 can get a car 500lbs heavier to low 8's. I think a larger turbo would make it much easier but your also not far off considering your goals.
You already have the S475 or still shopping?
Old Sep 20, 2019 | 12:19 PM
Still shopping around. There is a considerable price difference between the 475 and 480.
Old Sep 20, 2019 | 01:45 PM
SLOW SEDAN's Avatar
This isn't too much more then a cast 475, it'll make some jams: https://turbo4less.com/product/vsr-8...let-t6-1-32ar/
Old Sep 20, 2019 | 02:20 PM
Mathematically I need 900hp. And mathematically the S475/96-88 pencils out, but not by much. again, this is just math, no real world obstructions factored in.
Old Sep 20, 2019 | 02:21 PM
truckdoug's Avatar
damn thats a tasty deal
Old Sep 20, 2019 | 03:00 PM
yenkomike's Avatar
75mm billet or 80 mm cast will get it there. im sure a std 475 will get that weight in the 8's with the right setup.
Old Sep 20, 2019 | 04:08 PM
rryan5429's Avatar
My 6.0 with the cast 75 at 3200 on e85 went 8.70's. Have a billet 80 now. Haven't been on a good track with it yet. Have already run the same 1/8 with 4 more mph and I'm .06-.07 slow in 60'. Either will work .
Rick
Old Sep 22, 2019 | 08:50 PM
jester1's Avatar
Was that with a real 75 or the vs475 version?
Old Sep 22, 2019 | 08:53 PM
ls3fox's Avatar
7 Second Club
A real one but I would think a vs475 would do the same
