Holley or ms3 gold box??
Also, if you're running an electronic trans, go with the Holley. My experience with a microsquirt trans controller add-on is less than great. It works fine, but the setup isn't the easiest, and integrating things like gear/mph into boost control and traction control isn't as straight forward.
but they can both do the same stuff. closed loop fueling, and boost control
I have never used the MS3 with an electronic trans, but the holley was pretty easy to tune the trans once I had a line pressure sensor installed.
That is how I got mine. But that is without trans control. You need the max to control a transmission.
Holley HP EFI w/ Harness, Pressure Sensors, 3Port, Lcd, NTK Wideband Oxy 5 hrs of Use
they charge like $250 or $350 for that screen Separately .. works as a quick way to look things over/monitor stuff when you don’t have the laptop with ya. It’s worth the $100 imho.
but yeah your right. it is far from a replacement for the can cable and a laptop. You need the cable to do anything outside of the most BASIC stuff with Holley.
I just know with my truck I really hate lugging around the laptop when me and the wife go cruise. And if I wanted to do a little change or log I’d either have to have the laptop or go home and grab it. A nice lil screen would be really useful. I can use the efilive v2 to datalog but not make changes unless I had a already built tune loaded in the v2 and flash it. Wife doesn’t really like holding onto the laptop either.
It’s just another tool in the box. You won’t need it at all though if your buying the bigger Holley dashes. You can do a lot from those. The 12” one is super sweet. They just released another 6.9” or something sized dash that is pretty sweet and a lot less money than the 12”
Yes to basically all those questions. You have 4 inputs and 4 outputs. You can use the outputs for fan control, nitrous control, boost control, etc etc. The programmability is pretty wild.
and you have 4 inputs. These can be used for additional sensors such as a dome pressure sensor for better boost control, run a trans brake activated signal for timing control while staging or boost control while staging. Speed sensor I believe can be run here as well. Log coolant system pressure if you wanted to see if your having head gasket issues
You can log directly to the Sd card that goes in the 3.5” screen it comes with or with a laptop
And with the dominator you can remap any pin on the ecm afaik. you can control fueling on individual cylinders (as with the hp). As well as control more cylinders than the terminator can. And run low impedance injectors as far as I know
to it. I looked at the MS stuff at one time, seemed you had to buy some other stuff to
actually make it work, I wanted all in one. I found a guy that had good deals on the
Holley stuff. Just picked up the 3.5" screen for the new project, kind of flying blind
w/o it-great for picking what you want to view, then add in cautions to get your attention.
Megasquirt was created as an open-source project for tuning that has evolved over 15 years.
Starting as an open source project means that it was aimed more towards programmers and the DIY guys.
This is why the Holley is far more user friendly. The Holley works better for 95% of setups, not because it is better but because its easier to make work.
Megasquirts datalogging is light years better, though.
