Which catch can?
Old Mar 1, 2020 | 08:01 AM
99TAVert's Avatar
Default Which catch can?
I’m just about to start final assembly on this car and am looking for catch can recommendations.
Its using a Maggie TVS2300.
Long block is a 2011 Tahoe Hybrid all aluminum LZ1 6.0L, LS1 24x crank, LS9 cam, LS2 timing cover, 243 cathedral heads, Summit Pro LS Pistons and Rods.
Old Mar 1, 2020 | 08:03 AM
jayyyw's Avatar
I ordered one off this site. Waiting for it to come in.
Old Mar 1, 2020 | 09:30 AM
Rich-L79's Avatar
These guys make a pretty good one.
http://www.eliteengineeringusa.com/
Old Mar 3, 2020 | 02:33 PM
Black_Sunshine_99's Avatar
Been really happy with my MM PCV Catch Can.
Old Mar 5, 2020 | 12:40 AM
knickel's Avatar
Mighty Mouse,call David
Old Mar 5, 2020 | 01:23 AM
Dragframe's Avatar
Those look nice 👀
Old Mar 5, 2020 | 07:35 AM
973800CamaroRS's Avatar
I have the dual that on their site works great. I would recommend mounting it away from drivers compartment
Old Mar 5, 2020 | 08:56 AM
Tyler Dietzenbach's Avatar
I'd go with Mike Norris
https://mikenorrismotorsports.mysimplestore.com/products/mike-norris-motorsports-gen2-billet-pcv-oil-catch-can
The above is Gen 2. A few color combos available. Theres a gen 1 as well that's cheaper but less color choices.
Old Mar 5, 2020 | 01:15 PM
AwesomeAuto's Avatar
Mightymouse or Motion Raceworks both have really nice cans.
I use the $25 ebay ones with the two 10AN fittings and a filter on top, but they have no baffling other than a small screen, so I put the foam inserts in them.
Old Mar 5, 2020 | 06:53 PM
SCLT1's Avatar
Awesomeauto I just looked at those eBay cans how do you like them? They look pretty good. Where did you get the foam inserts and where did you get the hoses for it or are you just using rubber hose.
Old Mar 5, 2020 | 06:55 PM
Dragframe's Avatar
Couple good links in here. Gunna have to order me a new catch can now 😐
Old Mar 6, 2020 | 07:14 AM
I used these ~$25 ones with the screw on top/bottom so you can open them up. The welded versions on ebay are garbage and yet are the same price.
The only problem is that all they have inside for any kind of baffle fine mesh screen. That would at least be OK if it was above the fittings, but it is in between them.
My go-to is usually steel wool pads. I'll use a higher grit in the top, like a grade 4, and in the bottom usually something a little finer like a grade 1.
Stretch them out to fit their spots. The grade 1 will stretch a lot before it thins out too much.
I've also used these in the past but they aren't as easy to find, but still only $5 or so. Tetra pond filters. You can get them in almost any size and just drop them right in.
Old Mar 6, 2020 | 09:51 AM
Dragframe's Avatar
I have one sitting on the shelf in my garage I’m not gunna use. You get what you pay for (cheap junk).
Old Mar 6, 2020 | 11:54 AM
SCLT1's Avatar
I saw the one you have pictured so you use that one? Funny I was thinking of using aquarium sponge filters as I have aquariums so have used those in the post of power heads.
Old Mar 6, 2020 | 12:05 PM
Yeah I use that exact one pictured, with a pond pre-filter in both the top and bottom portions (one filter, I just cut it to fit).
I bought the filter from Amazon for like $8 shipped or something.
I have $35 in the catch can, $45 in a 10AN braided hose kit with fittings from ebay, and $20 in a pair of 10 AN oil cap replacement things since I run 2 passenger side valve covers.
$100 in the whole catch can setup. I couldn't bring myself to spend any more than that lol.
Old Mar 6, 2020 | 12:46 PM
SCLT1's Avatar
Okay great thanks I appreciate it and sounds good to me.
Old Mar 8, 2020 | 08:06 AM
jayyyw's Avatar
Because of the odor?
