A&A bracket question. Fixed idler not spinning. c5 bracket on fbody
Old May 1, 2020 | 05:41 PM
Psidls1's Avatar
Default A&A bracket question. Fixed idler not spinning. c5 bracket on fbody
I just installed the A&A procharger c5 bracket on my 02 Z28. Everything is good, running good, sounds good. However, I noticed the fixed tensioner isnt spinning. Could belt being too tight be the cause? Any ideas?
Old May 2, 2020 | 11:17 AM
Psidls1's Avatar
Noone?
Old May 2, 2020 | 05:35 PM
stevieturbo's Avatar
No.
But surely you have the car there in front of you to look to see what is wrong ?
Old May 2, 2020 | 05:53 PM
Psidls1's Avatar
I thought maybe the belt was too tight, but didn't make sense to me. Was hoping for maybe a quick "try this" or something. No worries though. Thanks for the reply
Old May 2, 2020 | 05:55 PM
Yes the quick answer is.
try removing the belt and looking at it.
Old May 2, 2020 | 05:57 PM
Psidls1's Avatar
I've had the belt off. Everything works as it should. When I put the belt back on it almost seems as it's tightened to a point where it's just barely nipping the fixed tensioner. Everything is fine, running fine, etc. This just puzzled me.
Old May 2, 2020 | 06:11 PM
What do you mean ?
You first post came across as if something was seized and not turning.
Old May 2, 2020 | 06:15 PM
Psidls1's Avatar
I'll get a picture tomorrow. I apologize for sounding "stupid". It seems as it's not spinning due to the belt just kind of grazing it. A picture may be a little more telling.
Old May 3, 2020 | 04:29 AM
So you're saying the pulley is quite capable of turning, just the belt doesnt touch it ?
Old May 3, 2020 | 07:25 AM
Psidls1's Avatar
Correct. Or, just barely touches it
Old May 3, 2020 | 08:50 AM
helga203's Avatar
Is it adjustable ?
Old May 3, 2020 | 08:55 AM
Psidls1's Avatar
The fixed idler, in question, isn't.
Old May 3, 2020 | 12:06 PM
Psidls1's Avatar
Bought .5 shorter belt, installed, spun crank slowly with 1/2 ratchet just to verify pulley movement. Everything is fine. Was just me, I guess.
