LSA Supercharger install on a C5 Corvette and what it takes to make it fit.
Old 05-17-2022, 06:52 PM
  #121
Mr. Black's Avatar
probably the tuner's fault
That most certainly could be but I'm just not sure how. It literally had no timing in it, lots of fuel, and very little knock retard would ever show up.
Old 05-17-2022, 09:20 PM
  #122
truckdoug's Avatar
yah ron and I were bs'ing about it earlier when he came over. says your set up would make near full boost at 1800 rpm? i'm no blower guy but that don't sound right. stuck bypass maybe?
The following users liked this post:
Mr. Black (05-17-2022)
Old 05-17-2022, 09:26 PM
  #123
Mr. Black's Avatar
Ha! To be perfectly clear NONE of this falls on Ron.
I don't think it's stuck. It would show in the logs. The map sensor shows no boost to boost.
That being said when it's up and running again I will make sure the diaphragm is working correctly. I have tested it before as well with my vacuum sucker and it fully cycled from open to closed.
Old 05-17-2022, 09:30 PM
  #124
Mr. Black's Avatar
Originally Posted by theunderlord
damn man. not fun at all. But a new build sounds like just the thing to start having fun with!
whats the plan? Rec port heads makes a ton of sense with the blower. Lower CR for boost? Forged pistons/rods? Displacement?
At this point I'd be totally ok with an Iron 6.0 stock crank stock displacement.
The following 2 users liked this post by Mr. Black:
Jimbo1367 (05-18-2022), theunderlord (05-17-2022)
Old 05-17-2022, 09:33 PM
  #125
Mr. Black's Avatar
Originally Posted by SwapStang
WOW! Well at least the carnage was a good show lol. I am definitely with you on getting a set of rec port heads they are so nice and to get rid of those adapters would be nice. Are motors really not cheap near you anymore? That is really a shame I hate hearing that. A gen 3 6.0 is probably $500 or less here (northeast) but a 5.3 or 4.8 can be had for $300 or less. I'm looking forward to the motor build! Keep it up!
Build it, Break it, Build it better.....
Average already pulled price for a 6.0 iron around here is 1700 to 2500 with a stupid amount of miles.
That being said there are a couple 6.0s at the local Pick N Pull but that is not the most enjoyable place to pluck and engine from especially if it's cold and muddy outside.
Old 05-17-2022, 09:46 PM
  #126
theunderlord's Avatar
^^^^ Yup and all the 4L80's up here have been snagged by a certain someone down in Portland.
6.2's are like 3,200 bucks, it's unreal. It's actually cheaper to look for crashed trucks and vans with 6.0's than it is bare engines.
truckdoug (05-18-2022)
Old 05-17-2022, 10:23 PM
  #127
RonSSNova's Avatar
I have my peeps looking as well. A good block and crank would suffice.
Old 05-17-2022, 10:50 PM
  #128
Mr. Black's Avatar
Well some good news. Looks like my PRC heads might be ok.
#1 and #2 plugs NOT smashed lol. Very oily lol.
Old 05-18-2022, 05:58 AM
  #129
JumboShrimp's Avatar
I'm F'n Speechless! (And nervous - very close to firing mine up) You are handling this WAY better than I would.
I keep thinking about when Princess Di was killed in a car crash - The headline read "Official Reaction - Shocked and Saddened". I certainly am THAT. You seem to have the right attitude though. Stay focused and... Build Back Better? -
(I can't believe I just said that. Please delete this post if I Offended anyone - LGB)
Mr. Black (05-18-2022)
Old 05-18-2022, 10:09 AM
  #130
SwapStang's Avatar
I'll have to pull a log of my car when I had the blower but I'm pretty sure mine was all in under 2000 rpm it was ridiculous, it was literally a light switch from off to on. I had stock pulleys so it was only about 8lbs but still a good kick in the pants lol. What about a 5.3 near you? Whats the price tag on those near you?
Old 05-18-2022, 10:25 AM
  #131
truckdoug's Avatar
are you 100% on staying with a stock pcm and 24x/1x? i am hearing reports of completely bonkers power numbers from otherwise stock bottom end L83's and adapters to fit LS intakes.
for now they are somewhat off the radar
Old 05-18-2022, 06:07 PM
  #132
Mr. Black's Avatar
I definitely want to go to square or rectangle port LS3 heads and keep this blower without running adapters. So that pretty much means 6.0 liter bore or bigger.
I am currently running a 411 PCM. I would like to stay 24x out of simplicity. No convertor boxes. Change reluctor wheels if needed. It would also be nice to stick to a generation where all my accessories just bolt right on? Knock sensors stay functional and so on.
Also as swapstang mentioned on the boost. I am pretty sure it is very normal for these PD blowers to pour on the boost nearly instantly. That is what they are known for. Doesn't matter if it's a Eaton, whipple, TVS, LSA, Kong Ect.......
Of course nothing is set in stone yet but I am leaning towards Iron 6.0 stock crank. Gen 4 rods, and forged dished pistons with compression around 9.5 to maybe 10:1.
SwapStang (05-19-2022), theunderlord (05-18-2022)
Old 05-20-2022, 09:09 AM
  #133
Mr. Black's Avatar
Man this is not looking good.
The blower is full of oil. Like a half quart. It's full of metal and locked up. The intercooler brick looks like it got shot with a 12 gauge.
The cam is smoked and the lifters most certainly are as well.
Heads will come off today. It's the only hope I have left of salvaging anything left of this engine.
This is going to be a long road to recovery.
Old 05-20-2022, 10:44 AM
  #134
SwapStang's Avatar
Oh man that sucks hopefully those rotors are ok. The first blower I bought looked very similar and was also locked up, long story short I took the entire thing apart, put new bearings in, and turned out one of the rotor lobes was bent ever so slightly. Needless to say I never ran that blower and bought another one considering $1650 for a rebuild, $1400 (at the time) for a used one or $1900 for a brand new one so it was easy math. I've got my fingers crossed for you.
So what exactly are we talking here? A few pistons actually came apart and sent shrapnel up through the valves and into the blower while the rods were punching holes through the block? Absolute carnage I'm patiently waiting for the autopsy photos...
Old 05-20-2022, 10:53 AM
  #135
holy crap! what the hell?
Old 05-20-2022, 01:55 PM
  #136
truckdoug's Avatar
my condolences
Old 05-20-2022, 08:00 PM
  #137
Mr. Black's Avatar
Well we got the heads off today. I can't say this for certain but it looks to me like the ring lands were in tact. The #2 piston is busted through the top but that was definitely secondary as far as the small portion of ring land is concerned.
Could the rods really have just let go?
Heads are going to be salvageable but there is a couple of bent valves so if I sell them they need some minor repairs.
Old 05-20-2022, 09:55 PM
  #138
dayummm man. that's some serious carnage.
Old 05-22-2022, 07:03 AM
  #139
Thanks for sharing all this with us. You're a better man than I. The amount of damage is incredible! All the little pieces in the blower is Crazy!
If you had to list 3 or 4 reasons why you 'think' this happened where would Detonation sit on that list?
I can't imagine the sound that made when it happened!
Old 05-22-2022, 09:40 AM
  #140
Mr. Black's Avatar
Based on what we've seen after the teardown and looking at the other 6 piston tops and all 8 plugs. I'd say it's not even on the list really.
We constantly monitor for knock retard so it's definitely not like we were just throwing caution to the wind.
I'm pretty sure I hurt this motor when playing around testing wheel hop cures. Of course we'll never know for sure.
JumboShrimp (05-22-2022)
Quick Reply: LSA Supercharger install on a C5 Corvette and what it takes to make it fit.
