New regulator
Old May 24, 2020 | 03:18 PM
corvettedave383's Avatar
Default New regulator
Hey guys, I fitted a new regulator, a aeromotive regulator x1 bypass regulator, the older aeromotive i had, had a -6an return port, so wanted to upgrade to a -8an return port, so fuel doesnt get overheated etc
since fitting new regulator, when on boost, the old one would boost ref 1;1 perfectly, 15 psi of boost and i get 15psi more fuel pressure, so the new one, doesnt seem to want to go any higher than 54psi, even tho iam at 15psi of boost, i know new regulator also had a higher fuel through put compared to the older version, my fuel pump is the same, it flows enough fuel for 1500bhp boosted hp
thoughts anyone?
Old May 24, 2020 | 05:24 PM
3 window's Avatar
Check the filters. Might be coincidence. I chased my tail for a summer.
Old May 25, 2020 | 01:28 PM
stevieturbo's Avatar
Originally Posted by corvettedave383
hey guys, i fitted a new regulator, a aeromotive regulator x1 bypass regulator, the older aeromotive i had, had a -6an return port, so wanted to upgrade to a -8an return port, so fuel doesnt get overheated etc
lolol
Old May 25, 2020 | 04:35 PM
lolol
thoughts?
Old May 25, 2020 | 04:36 PM
The thought of a change to -6 to -8 fitting on the return making any difference to fuel temperature, is hilarious.
Old May 25, 2020 | 06:06 PM
iam just going by what the fuel pump company say, they seem to suggest that too small of a return line, can make the pump worker harder, the pump gets hotter, which in turn heats the fuel, they also recomend you have a cooler on the return fuel line aswell
Old May 26, 2020 | 11:32 AM
They're stretching things just a little bit.....
Old May 26, 2020 | 12:45 PM
well thats what they say, not much more i can add really
Old May 26, 2020 | 12:48 PM
And listening to them has taken you from a setup that worked...to one that doesnt.
IMO, stay away from such companies.
Old May 26, 2020 | 01:32 PM
Forcefed86's Avatar
Id send it back... It's not working as it should. I've had surprising luck with the MSD 1/2" return regulators. Ran 4 of them now and I've never had an issue. My 4303 defiantly heats up the fuel still. If I have around 2 gal or less my fuel and pump and fuel get damn hot. I make it a point to stay mostly full. I was also told to run a -12 return from aeromotive... That company's advice and prices VS performance are ridiculous. If I had listened to them I'd have $3k worth of fuel system.
I agree with the above, stay away from them.
Old May 26, 2020 | 04:08 PM
ive got the magnaflow protuner 750 pump, they were the ones suggesting stuff about return lines and fuel getting hotter etc there pump, ive worked out the issue with the regulator, i had a aeromotive a1000 regulator on to start with which worked perfectly by the way, i knew it had a -6an return, so thought better buy a regulator with a -8an return as a min requirement of magnaflow, so went for the aeramotive again, same shape and size, so could use the same bracket on the engine etc, so decided the x1 was the boy for the job, so there are 3 versions, one for carb setup and the other 2 for efi, one for 150gph and one for 300gph, the magnaflow pump is rated for 164gph, so thought better get the 300gph regulator, thats what is causing the issue, it says on there setup sheet, that is the pump is not flowing enough fuel , the boost ref with struggle to match boost pressure, which is exactly whats happening, the older regulator which can handle 150gph worked perfectly, so iam geting the kit to change the x1 to a 150gph version, but still having the -8an return port, so should solve my issue
Old May 26, 2020 | 05:01 PM
Run your pump as a test with the engine off and see whether the fuel gets hot or not, and log temperature.
As always...most of the heat comes from the hot fuel rails, not the pump. And it's daft to say the return line causes it lol
Old May 26, 2020 | 05:33 PM
Forcefed86's Avatar
I'm sure it does. Was only stating that regardless of my -8 return, it still got hot. And without very much in the tank it gets continually hotter.
Old May 26, 2020 | 05:54 PM
smaller volume of fuel will always heat quicker, and be harder to dissipate any heat.
Old May 26, 2020 | 11:17 PM
LetsTurboSomething's Avatar
Are you deadhead plumbed or do you have the rails Y connected in with the regulator after the rails? Because if you are deadhead now the first thing I would do is go to a Y plumbing to get rid of hot fuel. Keeps the fuel moving past the rails all the time.
Old May 27, 2020 | 02:06 AM
A system that does not pass fuel through the hot rails repeatedly will always run cooler than one that does.
Which is one reason why some systems dead head.
Old May 27, 2020 | 10:11 AM
yeah got y into rails from one -10an, then y out to regulator and -8an back to fuel tank, via a cooler at rear of car
