Will this collector work
Old Jul 12, 2020 | 07:30 AM
kward's Avatar
Default Will this collector work
Running into a lot of space problems on a 69 RS with 6.0 and precision 76/75. Will this collector cause serious issues? This is the easy way out but I could possibly configure it for a more rounded entry with a lot more fab work. First turbo build so I need advice.
Old Jul 12, 2020 | 07:33 AM
kward's Avatar
Obviously it isn't finished yet, just looking for info before I finish cutting and welding
Old Jul 12, 2020 | 07:42 AM
Twin_Turbo's Avatar
Why not cut 2 weld elbows as a divided inlet into the flange. Just cut your weld el straight along the short tun perpendicular to the tube inlet
Old Jul 12, 2020 | 09:23 AM
TrendSetter's Avatar
not sure what the rest of the engine bay looks like, but i would avoid running it like that at all costs. will it run and make boost? sure, but i wouldnt expect it to do a very good job.
Old Jul 12, 2020 | 04:14 PM
Slow boi's Avatar
Step one. Buy the monkeyfab collector
step 2 find a spot for it
step 3 v band your headers
step 4 connect them all together.
that’s how I did it and it worked out, I would really really avoid that setup.
Old Jul 12, 2020 | 04:18 PM
truckdoug's Avatar
holy ****
Old Jul 12, 2020 | 07:39 PM
kward's Avatar
I already knew it probably was not going to work, I trashed it and fabricated one with nice transitions. Thanks for all the input.
Old Jul 12, 2020 | 08:40 PM
SLOW SEDAN's Avatar
Please dont buy a fancy flange for a 7675. You can make a merge and beat it even with a T4 flange in 30 minutes.
Old Jul 13, 2020 | 03:39 PM
Dragframe's Avatar
Those are sweet but hellll no lol
