Catch can
Old Nov 18, 2020 | 09:20 PM
Leigh12's Avatar
Default Catch can
Anyone no the right way to setup a 2 port catch can on a turbo Ls1
Old Nov 19, 2020 | 07:44 AM
dlandsvZ28's Avatar
IMO to do it right, you need a three port can. Most catch can systems are designed for NA (intake is always under vacuum unless WOT).
1)Center port is for crankcase port (dirty gases).
2)NA port with one way check valve when engine not in boost (NA - vacuum in intake)
3)Boost port with one way check valve when engine in boost (Boost - positive pressure in intake)
If your can is large enough you can add a port. The issue with most cans is that their inside volume is too small to work effectively.
Sent you a PM.
Old Nov 22, 2020 | 03:25 PM
Old Geezer's Avatar
Mighty Mouse here.
Old Nov 22, 2020 | 03:48 PM
Shownomercy's Avatar
Man-Crush Warning
I have a MM draft can setup to pull across the valve covers. It gets suction from post air filter, pre turbo.
Old Nov 26, 2020 | 10:13 AM
Jwooky's Avatar
Sent you a PM.
I have a similar setup except, like many others I am using a two port.
One line from the Turbo inlet that works as a vent under vacuum and vacuumed source under boost.
Disadvantage I see is you will draw dirty crankcase through turbo under boost.
With all that said , I still am creating back pressure to pop off the push in oil fill cap occasionally.
Old Dec 5, 2020 | 10:30 PM
knickel's Avatar
Yup.
Old Dec 6, 2020 | 12:16 AM
AwesomeAuto's Avatar
I just vent mine to the atmosphere with the largest ports I can.
Old Dec 6, 2020 | 06:53 AM
dlandsvZ28's Avatar
If back pressure is building in the crankcase to the extent it blows the oil cap off means that the check valves either under vacuum or boost aren't working correctly. As a result backpressure building in the can doesn't exit out of the can back into the intake side. Or the vacuum source to open and close the check valves isn't great enough.
Link to back pressure:
Vents like these will draw about 3 to five psi of vacuum if installed correctly on the inlet to the turbo or supercharger. The truck guys (Ford) vent cleaned air into the exhaust rather than back thru the turbo or the supercharger.
