Summit pro ls Rod and pistons
Old Dec 5, 2020 | 08:25 PM
lscamaro234's Avatar
Default Summit pro ls Rod and pistons
Hey all,
wondering if anyone has used the summit rods and pistons pro ls stuff? Any good?
5.3 block currently just got a hone and stock gear back in, will I need to pull the block out first and measure up too see if I need an overbore before hi buy.
also running a s475 t4 1.1 btr stage 2 e85.0
How much boost / horsepower could you run reasonably safe?
Not sure it would be worth doing a crank too, otherwise may as well go bigger cube block.
Old Dec 5, 2020 | 08:51 PM
Mavn's Avatar
"I MAID THEESE"
Originally Posted by lscamaro234
Hey all,
You wont even hurt a sbe engine with that turbo. But yes i made 1000 on summit stuff no issues with the pistons or rods.
Old Dec 6, 2020 | 02:14 AM
only gen3 rods pistons in it now.
putting in forged stuff is it as simple as balancing with the crank and throwing it in , or will i need hone or bore, motor was freshened only 2000kms ago.
Old Dec 6, 2020 | 03:51 AM
007FJ's Avatar
If it’s in good shape a hone for the new rings is all that is needed on the block. I’m sure the bob weight is different so the crank will need to be balanced For that
Old Dec 6, 2020 | 03:54 AM
007FJ's Avatar
If you got it in the car and all fresh, just run it I say. Ought to live to 650 on 93 just fine. Add a hundred if on e50 to e85
Old Dec 6, 2020 | 09:08 AM
matt1289's Avatar
I am using summit pro ls pistons and rods in my build. So far the quality looks great.
Old Dec 6, 2020 | 10:43 AM
jaydubb's Avatar
Hey all,
Richard Holdener made 1300 on gen 3 rods and E. Some have made 500 wheel and scattered the engine.
Old Dec 8, 2020 | 08:36 AM
Forcefed86's Avatar
Holdner is also applying a piddly amount of load to those engines on the dyno compared to "real world" loads. Also his 1300hp is everyone else's 900 hp . So take his power numbers stuff with a grain of salt.
If you don't load up the GEN3 stuff early in the RPM range (where they naturally make power) then you can make them live at much higher power numbers. I'd say less than 3% of the folks on this forum actually run the engines this way, its not very practical for a street/strip car. So unless you cam it to the moon and stall past PK TQ RPM, I'd keep it around 600 with gen3 stuff if you want it to live.
That said you can get gen4 4.8's and 5.3's for under $500 around here pretty easily. No down time, no machine shop bills etc... Personally I'd just grab a gen4 engine and go from there. The car will be done and running much faster. Gen4 rods/and pistons go for sub $200 all the time as well. Personally I like to pick up the whole engines. You have alot more spare parts and things to sell that way.
My 2011 alum 5.3 was $500. Sold the 243's immediately for $300 and the intake/inj's for $75. So I basically have a $125 gen4 alum short block ready to go. Then have spare bolts, covers, oil pan, WP, etc... All for less than the price of a hot tank, hone and cam bearing job at a machine shop... And I didn't have to wait a month for them to do all that. Nothing against summit parts, I'm sure they are great. I'd rather have a spare gen4 short block or 3 sitting around than have that cost tied up in 1 engine.
Old Dec 8, 2020 | 10:18 AM
jaydubb's Avatar
Agreed. I wouldn't try it with Gen 3 rods. But you can make some good power with them. I have an late LQ4 with the Gen 4 rotating assembly. Shooting for 700-800whp. It should live... Should... Lol
Old Dec 8, 2020 | 07:24 PM
007FJ's Avatar
Hold my beer and watch me this weekend. I'm going to see if Cesar can squeeze maybe 800 Wheel on my Precision 76/75 CEA. I hurt a piston my high dollar 6.0 a few weeks ago most likely because of back pressure from the little Precision. My brother had a stock 2003 4.8 in reserve. Put a set of ported stock valve sized 243s and a 214/220 TSP Turbo Cam. LS6 Intake, ID1300s, E85, Huron V3 T4 AC Kit
We put it in and I almost have it ready to go to HPF.
Old Dec 9, 2020 | 11:16 AM
Kfxguy's Avatar
I have the summit rods and pistons in my 5.3. you can read my build thread. My opinion is this: you can chance a SBE engine, you might get lucky, you might not. If you are using good heads (ported or aftermarket) I wouldnt chance it. Thats just me. I built mine so I can lean on it and not have to worry about it. I cheaped out on **** and it came back and bit me in the ***. Dont cheap out unless you like to spend more money than you would just doing it correctly AND you'd rather work on your **** than drive it.
You ask a question here, your likely to get 10 different answers....so You'll have to make your own decision.
If you destroy the SBE motor, then thats one less block and possibly set of heads that you have.
mine has seen 22psi on the regular and 24psi from time to time. On 93 pump gas.
btw, I broke a piston in my SBE gen 4 ls1 (ls6 bottom end) in my gto at about 11-12psi. I thought it was because I ran it too lean, but most are saying 11.6-11.8afr wasnt too lean and i old had timing at 11 degrees.
Old Dec 9, 2020 | 12:17 PM
SLOW SEDAN's Avatar
I would hope the billet precision unit makes 800+, guys are doing that and more with gen 2 taiwanese tornados that cost half as much.
Old Dec 9, 2020 | 01:27 PM
007FJ's Avatar
Stock Gen 3 4.8 being the point...per the original poster discussion
Old Dec 10, 2020 | 08:32 AM
SLOW SEDAN's Avatar
Exactly hasn't he made almost 1000 on those.
Old Dec 10, 2020 | 09:53 AM
007FJ's Avatar
We both know the PT 76/75 isn't going to make 1000 even on the 4.8 especially through an unlocked 4L80 and a 9"
Whatever point your making by turning the replies into a debate and defense session of my "weak ***" combo isn't worth the hassle. I posted it to let the OP see what stock Gen 3 stuff is doing on here with current posters and non race dedicated setups and a good tuner. 775-800 would make me happy, Anything more will be icing on the cake.
We should see how it rolls tomorrow.
Old Dec 10, 2020 | 10:02 AM
SLOW SEDAN's Avatar
Wasn't debating anything, and never said it was weak, in fact I said I hope you make more! Not sure what you are reading into my statements but apparently its not what I intended.
I was simply saying that numerous people have made near 1000 with SBE 4.8's and that many have made over 800 with 76mm turbos so you shouldn't have any issues reaching your goal. Not sure where the confusion is.
Old Dec 10, 2020 | 10:10 AM
007FJ's Avatar
Well I apologize for being bitchy then. I'll blame it on lack of sleep the last two weeks and get my *** out in the garage and get the cold side, plugs, coil packs, exhaust and all of that other little stuff that seems to drag out right before you are "finished".
Old Dec 10, 2020 | 12:22 PM
Forcefed86's Avatar
Skinnies made 850 on a mustang dyno unlocked (TH400) with the 76/75 on a 5.3 in his old RX-7. Then turned up the boost and went quicker. I know it's already been said, but there's an actual example. Believe that only trapped about 159 at that power level/boost setting well... Same turbo trapped 164 turned up more. (super light car but still making north of 850whp).
Old Dec 10, 2020 | 03:58 PM
Shownomercy's Avatar
Man-Crush Warning
Curious what the limit is for a larger CI motor on a 76/75, like a 6.0 motor and up
Old Dec 10, 2020 | 05:35 PM
Summitracing's Avatar
LS1Tech Sponsor
Hey there, we put quite a bit of effort into crossing the t's and dotting the i's on these. They are working well for people. We came out with 3rd gen, 4th gen, and 6.125 rod versions to for people on different budgets. Feel free to ping us anytime on your combination and we're happy to help put together the part numbers you need to fit the bore size etc.
__________________
800-230-3030
www.SummitRacing.com
