Broken weld on the intake
Old May 1, 2021 | 04:19 PM
Jwooky's Avatar
Default Broken weld on the intake
The car started idling really high. Headers also got really blue. Eventually found this. This is the back on the intake. It saw ~20 lbs a few times when I first built it, until I got the gates set up properly, then ~10-12 lbs since for the last 1000 miles.
it was only last couple times out it started idling high.
You can see how blue the headers got. Running lean obviously. 😳
Old May 2, 2021 | 03:37 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Thanks for the update. Now weld it back and **** up some tires.
Old May 2, 2021 | 07:49 AM
Old Buzzard's Avatar
Just my $.02
2 things come to mind.
1. Metal is very thin.
2. Sumting Wong welded only 1 side.
I would consider at least removing the thin end plate, removing the old weld bead, and adding something heavier.
Welding over prior weld is not going to enhance the reliability.
A math exercise: area x pressure.
Also, "only 10psi", is just the starting point!
Old May 2, 2021 | 08:30 AM
Jwooky's Avatar
exactly what I plan to do
Old May 2, 2021 | 08:32 AM
Jwooky's Avatar
Originally Posted by Old Buzzard
Just my $.02
I tend to agree. I can weld it on the car, so I’m going to give it a shot and keep an eye on it.
If I have to remove it I’m going to just replace it.
Old May 2, 2021 | 08:18 PM
Stonerracing's Avatar
You blew the welds on the intake! Dom
Old May 2, 2021 | 08:36 PM
Originally Posted by Stonerracing
You blew the welds on the intake! dom
25psi into a Budweiser can will do that....
Old May 2, 2021 | 10:14 PM
gjohnsonws6's Avatar
A soda can has a burst rating of 100 psi.
Old May 3, 2021 | 07:59 AM
rotary1307cc's Avatar
They have inadequate material for the shape and load that it sees
Flexing is what makes the weld fail
Old May 3, 2021 | 11:37 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
what brand is it
Old May 3, 2021 | 03:44 PM
Zmg00camaross's Avatar
Ho lee **** welded that I am betting.
Old May 3, 2021 | 04:29 PM
...at age 12, while getting payed in rice cakes.
Old May 4, 2021 | 06:08 AM
yenkomike's Avatar
i had one start cracking in the same place . just a thin pos if you ask me. mine was a ls3 port. pulled it off and put a ly6 truck intake in its place and the total power out put increased from idle to full boost picked up mph the entire run.
Old May 4, 2021 | 08:44 AM
I like rice cakes too 😛.
Old May 4, 2021 | 09:53 AM
Jwooky's Avatar
Haha
I’m sure you’re all right.
im going to weld R up and give it one more chance.
if it gives me any more issues I’ll be back to discuss another option. It has to be aluminum though. The appearance is important to me.
Old May 4, 2021 | 10:37 AM
SLOW SEDAN's Avatar
Seen a few of these break both ebay and Holley versions. Friend blew his Holley version at ~22psi exact spot as yours, welded it back up and its been fine since.
As for the chinabay headers, they all turn colors with heat even if your A/F is good.
Old May 4, 2021 | 03:29 PM
tblentrprz's Avatar
While you're in there, position a 1 to 1.5" .090" flat strip across the back panel. A bead on each side should to keep panel from flexing so much. That panel is likely 30+sqin. At 20psi that's 600lbs of force jacking with it.
Old May 20, 2021 | 11:43 AM
Forcefed86's Avatar
It will likely be fine once you reweld it properly. Those are VERY often "cold welded" This gives them a pretty appearance and is cheaper and easier to train people to do. Its not near as strong as an actual weld where the heat penetrates deep into the metal. (more like brazing) Though it may happen again somewhere else once you weld up that area. Most of the intakes went to thicker material. Maybe thats an old batch? See if you can mic the metal thickness. Might be better off ordering the newer thicker material manifolds... Believe the newer ones are 3mm thick. The one I had was roughly that anyway.
Good luck! Let us know!
Old May 23, 2021 | 09:43 AM
Jwooky's Avatar
Had it Tig’d and holding up so far. Haven’t driven a lot, but beat on it pretty good when I did.
it is a older version ~5years old. That back plate is definitely not 3mm, more like 1.5mm.
