spark plug help
Old Aug 1, 2021 | 11:48 AM
joes1966's Avatar
Default spark plug help
im running a 5.3 ls around 20 psi and using ngk br7ef plugs in it.I had another racer suggest going to a 8 but cant find the number for the 8 in ngk.At least I cant find any ngk br8ef plugs..Would love a cross reference or opinion on the plug number..thank you
Old Aug 2, 2021 | 09:59 AM
Forcefed86's Avatar
They arent listed that way as they are not "resisted" plugs. To go to a resisted plug you either need to spend a fortune on iridium plug, or go to a resisted boot and run standard 8 heat range plugs.
iridium drop in's are TR8IX or NGK 3691
Standard 8 heat range recessed pugs are B8EFS NGK 1049
I use the boots and REALLY like them. They literally screw onto your wire so install is a breeze and there is a defined snap when installing them on the plug. They are also hard plastic as opposed to the soft rubber junk. I use standard OEM style wires, nothing fancy there. A lot of interference and VR signal issues (crank/cam sensor) can come from using the large diameter poorly insulated wires.
NGK 8031 Spark Plug Boot Cap
https://www.ebay.com/itm/33384806556...kAAOSwpbpf9NiM
Old Aug 2, 2021 | 11:05 AM
joes1966's Avatar
I ended up buying the 1049 plugs from ngk.i had never heard of the boots before so thank you for posting
Old Aug 2, 2021 | 09:09 PM
f8lvenom's Avatar
What's wrong with your current plugs to necessitate a colder plug?
Old Aug 2, 2021 | 09:34 PM
joes1966's Avatar
nothing wrong with current plugs just wanted to try a step colder.Still experimenting with the ls stuff so wanted to see how the car responds and acts with a colder plug
Old Aug 3, 2021 | 07:52 AM
Forcefed86's Avatar
It's also a setup without an IC. Honestly even with an IC and water meth, the BR7's at 23lbs and 14* were getting down into the bend on the ground strap with my setups.
Old Aug 3, 2021 | 09:58 AM
joes1966's Avatar
yeh just wanting to try the 8 plugs.I ran my car friday again and got a 5.7 which should of been a 5.6 but think It could be meth or something.It bogged in high gear and was wondering if it was to much meth.I have the car very slightly rich on e85 for the combo and used the number 6 nozzle for meth.When I shifted in 3rd it seemed to have a bog.Next time out im going to have the 8 plugs with slightly smaller gap in them.I also have the meth coming in at a higher boost like 14 psi and not sure yet but may go to a 4 nozzle.When im on the brake you can tell when the meth comes in because the turbo starts building boost and then you can feel when the richment of the meth comes in.Still working on it and appreciate you comments..
Old Aug 3, 2021 | 04:01 PM
Forcefed86's Avatar
Meth/water plays hell on the 2 step when it comes on and off in my experience. The nozzle dribbling after its shut off can be annoying and then some as well. What ever you launch at boost wise, I'd set it over that point so it doesn't' come on when staging. You likely don't need it until 2-3 sec into the run. I feel you could have it kick on at 20 and you'd still be fine. The higher you have the turn on point the less likely you are to bog at healthy amounts. Also you don't need to be super rich with meth on top. I'd set it at a conservative 11.0-11.5 with no meth. (not sure how rich you have it) Progressive is honestly the way to go... but not practical for all. What ECU? Can you just PWM the meth pump?
Old Aug 3, 2021 | 07:50 PM
joes1966's Avatar
Old Aug 3, 2021 | 07:54 PM
joes1966's Avatar
I posted a pic of the plug from my car.It might actually be slightly lean.I cut the threads off and its got some tan but also some black specs on it.I got a new set of plugs and will use old for warmup and then tow the car to the line and make my run with new plugs.The plug in pic I ran and then took out after a pass.It was in the car dooring a couple passes so its not 100% the way it needs to be when checking plugss.I will be alot more accurate next time out
Old Aug 4, 2021 | 02:05 PM
Forcefed86's Avatar
For comparison, my plugs look almost new after a pass on E85. Zero soot/black. No real visible fuel line either. Nickle plating is all still shiny and new aside from the strap. Do you have a WB02?
Old Aug 4, 2021 | 05:23 PM
joes1966's Avatar
I have a lm2 wideband and can record on it.I use the lambda scale and its usually around .70 on the scale.The plug in the picture is after the 3rd pass so didnt get to do exactly what i wanted to on them this time.The plug looks really bad in the picture but isnt that black,I dont know whats with the pic.I posted it mostly for the strap and the ring around porcelin.
I have 2 sets of new number 8 plugs that just came in so will warm them up with current plugs and tow the car to the lanes.Shut if off after pass and check them then..Just havent been as smooth lately as I like.I have had the timing all over the place and put meth etc on it and no matter what I do I cant seem to keep the ls engines sealed.I always push alittle water so I was thinking maybe to lean even though the wideband says im ok..Im going to be really diligent on the plugs next time out..
Old Aug 5, 2021 | 11:39 AM
Forcefed86's Avatar
.70 is 10.3 on gas scale. That's beyond the peak rich power window for E85. I'm not saying you'll pick up 50 hp, but there's really no reason to go richer than 10.8 or .75 or so with E85 IMO. Factor in the meth and your likely around 10.1: ratio. Defiantly too rich. Its extremlyhard to read the fuel line on an ethanol plug. Most rely on the WB02 for this.
Your also not spraying much meth at all IMO. I'd step up to your biggest Meth nozzle, what ever that may be and have it kick on at higher boost levels to eliminate "bog". Target about 11.5:1 (.78 ish) AFR on E85 with no meth. I forget this isn't always the easiest for carb guys. Its 2 clicks for us EFI guys.
What I like to do is get a read on all 8. Find your leanest cylinder, and just swap plugs out of that cylinder. No reason to waste 8 plugs every time to get a read IMO. I pop one new plug in before a run and setup my timing table off my hottest cylinder. (oddly enough #4 in my case)
IF you are pushing water I'd dial back the timing at PK TQ. That's where your cyl pressures will be the highest. I don't put diddly for timing in my stuff until 5500+ RPM wise. much better off adding another 2lbs and dropping 3-5* out of it until its dialed in and not pushing water IMO. Personally I'd pull timing until it didn't push water. Then slowly add boost up top.
Good luck! hope you get it sorted! Sounds like there is a lot left in it. Always curious to see how the hot air stuff runs.
Old Aug 5, 2021 | 02:57 PM
joes1966's Avatar
thanks so much I really appreciate your post.I did take a engine apart and found that the ebay gaskets are only 3 layers.Im going to put a brain tooley 7 layer on next time out.I didnt realize that there were different gaskets and still be called ls9..once again thank you for all the info
