Twin Garrett T04B90
Old Jul 21, 2004 | 02:01 PM
EightBall's Avatar
Question Twin Garrett T04B90
With a .60 A/R compressor housing with a 3 inch inlet and a 2 inch outlet. It carries a 54 mm compressor wheel. The exhaust housing carries the TO4B turbine wheel and has an A/R of .96. Exhaust housing has the 4 bolt flange pattern.
My question is will these work on an LS1 and if so, how well? I am new to turbos and I am trying desperately to learn and I've been reading and searching a lot on this site but still need some guidance. Thanks
Old Jul 21, 2004 | 02:09 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Yes 2 of those turbos will work, also it will depend on what your goals are. As for turbo help, try this link below....
Click here
Jose
Old Jul 21, 2004 | 02:20 PM
EightBall's Avatar
Click here
Jose
Thanks for the info Jose. I was fortunate enough not long ago to come across another of your posts and I went to that website...great help. As for the aforementioned turbos, what can I expect on a stock LS1?
Old Jul 21, 2004 | 02:22 PM
EightBall's Avatar
Also, if I were to go with a single turbo application as opposed to a twin, what would be a good route to go if I wanted comparable performace to the twin T04B90's?
Old Jul 21, 2004 | 02:31 PM
LS1TECH Sponsor
A 58mm compressor will flow about 57 lbs/min of air. Thats enough for ~590-600 crank HP. As for equivalent single, your looking at a minimum of a T76-GTS or PTE-88.
Jose
Old Jul 21, 2004 | 02:39 PM
EightBall's Avatar
Jose
Sweet, had no idea 590-600 was possible for those turbos...I'm aspiring more in the range of 450-500 at the wheel, so going a little smaller would be reasonable I'm guessing. Also, I really don't want to be pushing monstrous boost levels. Any more recommendations? Thanks again...
-Mario
Old Jul 21, 2004 | 02:46 PM
LS1TECH Sponsor
The only drawback to that unit that will restrict the HP is the B cover. Its a little smaller then I would like. I definitely wouldn't go any smaller.
Jose
Old Jul 21, 2004 | 03:04 PM
EightBall's Avatar
I looked again at that website that you recommended that I said I had already seen, and I wasnt sure I understood the air consumption tables and compressor maps, but now I think I do and it helps a TON...
Thanks again Jose
If anyone else has any recommendations at all about achieving 500rwhp via turbo let me know...
-Mario
Old Jul 21, 2004 | 09:42 PM
99Fbody99's Avatar
-Mario
Eight Ball, Seeing how no one is paying attention..that 600hp EACH..not a pair. If your target is 500ish look at a pair of GT25 or GT28s or other t3 based units. More than enough turbo with great spool time.
Dave
Old Jul 21, 2004 | 09:53 PM
Jammer's Avatar
I was just gonna say that. I'd love to see another come join us freaks. Just have some bones the throw at it. Its a snowball. Just found out my built tranny didnt make it through tuning.
Dave
Old Jul 21, 2004 | 09:59 PM
iB2slow's Avatar
im looking into doing the same thing but i was thinking the t04b would be a little more than i need im lookin for 550 600 street rwhp but i didnt know which turbos im doing a custom incon setup you can come across the t04b or the t04e's CHEAP though. what are your suggestions Jose?
Old Jul 22, 2004 | 01:07 AM
Ryan K's Avatar
Pathological Modifier
I was told the TO4B90E's were good to 400hp each?
Thats my plan anyway, as I have a pair of those sitting on the shelf in my garage for my 6.0L truck.
Ryan K.
Old Jul 22, 2004 | 08:06 PM
red ws6 99's Avatar
Dave
They may support that much each, but you never want to run at the maximum output, way to inefficient. The Incon's are good for 880 fwhp but you would not want to run them past 600-650 fwhp because you are out of the center island.
Gary
Old Jul 23, 2004 | 01:20 PM
EightBall's Avatar
Yeah I like the fact that theres not too many turbo LS1's around and that makes me want it even more As for puttin money into it, Im about to put it in a garage on jack stands for the winter in a few months so I'll have alllllll winter to save up and work on it. Hopefully with help from you guys on this site and a few turbo DSM expert friends of mine I'll have the thing running by next spring...
Been shopping around and I found a Garrett T3/T04E for 549.00 with the following specs:
COMPRESSOR SPECS:
flow: 53 lbs/min 678cfm
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
Should I just stick to a 50 or 57 trim for the same price for what Im lookin for? The 50 flows 46 lbs and the 57 flows 50 lbs...
Once again, thanks to anyone who takes the time to help me out.
My Turbo TA revival project has begun
-Mario
Old Jul 23, 2004 | 06:50 PM
Mark C's Avatar
Yeah I like the fact that theres not too many turbo LS1's around and that makes me want it even more -Mario
There's more than you think, and they are closer to you than you know. Go with a single. I want to be the only twin turbo LS1 in CT.
If you ever want to see the packaging on an Incon, let me know.
Old Jul 24, 2004 | 12:24 AM
Jammer's Avatar
Or drive 2hrs to see my twin kit in Albany.
Old Jul 25, 2004 | 11:21 AM
EightBall's Avatar
Thats exactly my point though...if youre the only TT LS1 in CT, I bet that means theres not too many turbo LS1s to begin with...
And yeah Id love to see it some time
-Mario
Old Sep 30, 2004 | 09:24 PM
BSRMotorsports's Avatar
I also have two t04b90's but I can't find a compressor map anywhere for them, did you get them off ebay also?
