IAT Placement With Forced Induction & Alky Injection
As for nozzle/IAT sensor placement, I've always welcomed some potential wet-bulb temp discrepancy. Without telling the ECM that there is methanol present, it doesn't know the average fuel quality has improved. So you lose out on extra advance you might run if the methanol injection was fully integrated with the ECM. Next best thing is a slightly undershooting temp reading, keeping your spark a little bit higher. I always place my meth nozzles several feet from the sensor though...essentially as close to the IC output as possible. Works well in all but the most extreme setups.
Can def get away with more lead. I just worry about distribution issues with single point injection. I treat it as extra insurance. Setup the tune so its fine without... then add 7-12gph depending on power being made. I can see a difference in the plug heat reading with my 10gph of 50/50 on around 900-1000 chp. I actually lost MPH going higher than 10gph. I don't alter the tune up. Traps the same with the meth on/off. Just puts up the same # with a cooler CC.
Thousands of people have ran speed density with no maf and sprayed meth pre IAT sensor with no issues. It actually gives you an extra safety opportunity with meth based upon IAT you can pull timing.
My AFR is always correct and I have the old syclone iat not one of the new whiz bang super fast reaction ones. The only time my afr gets off is very long periods of idling it will start to lean out which isn’t an issue at idle and then returns to normal as soon as I start moving again. That’s a fairly normal issue with speed density and has nothing to do with the meth. The ect iat bias can help reduce that as well. This is obviously a gen3 setup.
Ive had much bigger problems with afr when my ect sensor failed lol.
