Final #'s 1560hp 1186ft lbs
Old Jul 23, 2004 | 10:09 PM
MECHAM's Avatar
Originally Posted by 1dirtyZ
what head gaskets are you using?? is it a stock ls1? 6.0? any more info on the heads and block?
i'm shocked! great numbers man!
some info
Built a 402 ci iron block forged shortblock for a customer with a single 94mm turbo.
Head gasket is SCE copper.
Dyno fuel is VP C-16.
TEA Z06 cylinder heads.
8.2-1 compression ratio
Cam Motion solid roller
Jesel lifters, rockers and belt drive
Wheel to Wheel sheetmetal manifold with 105mm throttle body
Daily pan and dry sump pump
Wheel to Wheel main girdle with steel main caps
Wheel to Wheel Distributor drive
FAST controller
Warbird's Avatar
No need for words
Old Jul 23, 2004 | 10:18 PM
V8_DSM_V8again's Avatar
Originally Posted by SC-MECHAM-WS6
some info
How much.....
Also what head studs were used?
STD ARP's C5R's etc....
Old Jul 23, 2004 | 10:27 PM
MECHAM's Avatar
Originally Posted by V8_DSM_V8again
How much.....
oops...i got that info from here... https://ls1tech.com/forums/forced-induction/194510-guess-turbo-hp-fun.html
Old Jul 23, 2004 | 10:28 PM
XLR8NSS's Avatar
Adkoonerstrator
I think I came closes at 1448 on hp.
Old Jul 23, 2004 | 10:32 PM
frcefed98's Avatar
Nice, and they said a 1500hp LSx couldn't be done lol. That looks to be @1300 at the wheels with 18% loss for drivetrain Great work guys and keep pushing those limits.
J
Old Jul 23, 2004 | 10:47 PM
oops...i got that info from here... https://ls1tech.com/forums/showthread.php?t=194510
Yes I saw that thread but no mention of what studs were used or the price of the girdle...
If it is a billet girdle an LS1 would have a deep skirt and 6 bolts on each main in addition to the billet caps.. That is tougher than a brodix little M with billet caps bottom end...... Its a F8cking anvil.
427's Avatar
427
The main girdle system is fairly new to us. This is the first engine to run with it in place. I don't have a price on this by itself at this time.
The headstuds are ARP 1/2 inch units that we use after machining the block for them.
Kurt
How much.....
Old Jul 23, 2004 | 10:57 PM
Kurt
What do you think about girdles. I know on turbo buicks some hate them some love them... Did you put dowels on the caps anywhere to index and maintain alignment.... IMHO I was considering that on the LT1... Alot of aftermarket blocks have them for good reason...
I could see how an ARP 1/2 inch stud could find a home with a little massaging..
Think theyd hold at 25psi but with a C:R for alcohol at 25psi.... I'm gonna be 0-ringing the deck and heads too..
Old Jul 23, 2004 | 11:06 PM
427's Avatar
427
Originally Posted by LSs1Power
Great numbers... Is that Wheel HP or crank HP? Can u post the dyno sheet. I would love to see how that HP climbs soo freaking fast.
The engine was run on our engine dyno, all numbers are at the flywheel.
I can't figure out how to post a dyno sheet so I will type in some numbers below.
rpm tq hp boost
5000 1004 956 19.6
5100 1040 1010 20.7
5200 1074 1064 21.7
5300 1081 1091 22.7
5400 1109 1140 23.7
5500 1132 1185 24.4
5600 1151 1227 25.0
5700 1163 1262 25.3
5800 1169 1291 25.5
5900 1176 1321 25.6
6000 1179 1347 25.5
6100 1181 1371 25.3
6200 1183 1396 25.2
6300 1183 1419 25.1
6400 1184 1443 24.8
6500 1186 1468 24.6
6600 1186 1490 24.3
6700 1186 1513 24.1
6800 1181 1529 23.8
6900 1171 1536 23.6
7000 1171 1560 23.4
Old Jul 23, 2004 | 11:25 PM
BlwnTA's Avatar
7 Second Club
Pretty incredible Kurt...
Old Jul 23, 2004 | 11:32 PM
  #32
rpm tq hp boost
5000 1004 956 19.6
5100 1040 1010 20.7
5200 1074 1064 21.7
5300 1081 1091 22.7
5400 1109 1140 23.7
5500 1132 1185 24.4
5600 1151 1227 25.0
5700 1163 1262 25.3
5800 1169 1291 25.5
5900 1176 1321 25.6
6000 1179 1347 25.5
6100 1181 1371 25.3
6200 1183 1396 25.2
6300 1183 1419 25.1
6400 1184 1443 24.8
6500 1186 1468 24.6
6600 1186 1490 24.3
6700 1186 1513 24.1
6800 1181 1529 23.8
6900 1171 1536 23.6
7000 1171 1560 23.4
Do you all realize how close he came to a quad turbo aftermarket big block at those RPMs. Using just a bolstered production truck block and a single 94mm turbo!
5,500 1,115 1,168 24 < 7
6,000 1,194 1,364 24 > 17
6,500 1,256 1,554 24 > 118
7,000 1,299 1,731 24 > 71
Granted that is almost midrange for that motor but it is still a new age mouse with one turbo vs a big fat genetically engineered lab rat with 4 on it... The W2W 1560hp LQ9 block single turbo vs a quadturbo GM DRCE block at 2100hp.. Figure out the HP per dollar and specific output differences between those two...
http://www.popularhotrodding.com/eng...05em_turbo_bb/
Old Jul 23, 2004 | 11:45 PM
  #33
427's Avatar
427
The quad turbo's on that car where sized a little off and we had to make some bends that were not as good as they should have been to get it to fit. Also we did the "quadzilla" about 4 years ago, the turbo's are jumping in leaps and bounds in technology.
Mike's current twin turbo 540 has two of the same basic turbo's that I have on this 402 (I only have one). His Monte Carlo has gone 6.29 @ 240 mph with the new engine, if you math that out at 3000 pounds he is at about 3000hp at the flywheel!!
Kurt
Do you alll realize how close he came to a quad turbo aftermarket big block at those RPMs. Using just a bolstered production truck block and a single 94mm turbo!
Old Jul 23, 2004 | 11:57 PM
  #34
Kurt
You still kicked *** with some pretty normal and affordable parts with that new motor...
All hail kurt... all hail kurt.... O say kurt you see
Now I'm thinking 3.25 x 4.030 in the LQ9 block with long rods so I can run small skirts, good angles and less friction.... Any pointers....
Oh and tell Mike the VNF hood which bears his name rocks...
Old Jul 24, 2004 | 12:18 AM
  #35
stage274's Avatar
holy cow!, thats what I am talk about some real horsepower and boost , way to go.
rpm tq hp boost
5000 1004 956 19.6
5100 1040 1010 20.7
5200 1074 1064 21.7
5300 1081 1091 22.7
5400 1109 1140 23.7
5500 1132 1185 24.4
5600 1151 1227 25.0
5700 1163 1262 25.3
5800 1169 1291 25.5
5900 1176 1321 25.6
6000 1179 1347 25.5
6100 1181 1371 25.3
6200 1183 1396 25.2
6300 1183 1419 25.1
6400 1184 1443 24.8
6500 1186 1468 24.6
6600 1186 1490 24.3
6700 1186 1513 24.1
6800 1181 1529 23.8
6900 1171 1536 23.6
7000 1171 1560 23.4
Old Jul 24, 2004 | 12:27 AM
  #36
69firebird's Avatar
You can find those girdles on E-bay, they really arent that expensive, but I am sure that the machine work isnt the cheapest
ed
Old Jul 24, 2004 | 06:52 AM
  #37
Guido's Avatar
Good job Kurt! That is amazing!
Old Jul 24, 2004 | 08:47 AM
  #38
427's Avatar
427
Its going to ship in about a week. Better get your drivetrain ready!! I would sure like to see this baby in a F car....but its not going to happen. I have seen pics of the car, it is sweet except the driver sits on the right side???
Kurt
Originally Posted by Reckless
Thanks for all the hard work Kurt....pack it up and send it down
Old Jul 24, 2004 | 09:02 AM
  #39
427's Avatar
427
The girdle on this engine was designed and built by W2W powertrain. It is not the one that is on e-bay for sale. (that one looks good though) Our girdle goes across the main caps and under the oil pan to tie in the lower skirt of the block. It required studs that are longer for the mains.(ARP made these for me) Also the oil pan gets spaced down about 1/2 inch. This would be something you would only use on a extreme application.
Kurt
ed
Old Jul 24, 2004 | 09:13 AM
  #40
Jammer's Avatar
Kurt and W2W does it again!
