Fuel system compatibility
3) Most aftermarket rails are 5/8" ID now, but they usually have a -8ORB thread on the end. There is no issue feeding each one with a -8AN line (1/2"). It's just nice to have a little extra internal volume so that individual pulses are better absorbed.
6) The larger the turbine (or higher numerical A/r), the less it needs to divert to the wastegate when trying to control boost. If the turbine is on the small side, you will need more wastegate flow to avoid excessive backpressure and boost creep. Running small-ish turbines is not the most efficient way to go, but it certainly can work.
I have seen people make ~800hp on the GT30's that came with the base C5/C6 APS kits and 1000hp with the GT35's in the Z06 kit. You actually have a decent amount of turbo(s) there.
The only "issue" I've encountered is I'm unable to get my fuel pressure below about 45psi base.
Now the BRFPR I'm using only goes down to 40 psi so maybe I need a different BRFPR or maybe my -06 return is providing a little restriction.
At this point I have no plans to address any of it.
Seems to work fine so far.
You have to figure most set their base around 60psi, just like GM does. Add 20lbs of boost to that and you are at 80psi. The 450’s or 525 hell cat pumps hate pressures that high in my experience. At minimum run 40 base, (I’d run around 30). I’m not saying the 450’s can’ t make lots of power. Just that many are disappointed when their dual 450’s run out of steam MUCH earlier than they expected. Look at Matt Happel, he had to run 3 of them to hit 1000whp and ran some massive wiring and relays to each as well. Then you have guys running 2 AEM400’s and making 1300ish if plumbed correctly with good voltage. They just handle pressure better by design.
The 450’s also pull more amps. At 80psi the 450 runs 18A+ So 36ish amps for 2.
The AEM400 is around 14A at 80psi so around 28A.
Factor all that in and the AEM is the better performing pump all around.
I’d put the regulator wherever it is most handy. Ideally the shortest run back to the tank will have the least amount of restriction. So it will heat the fuel less. Yes, you should to run a vac line form the manifold back to the regulator.
With a surge tank the pump used to fill surge should be small. it will have low pressure and low amp draw. I use an OEM pump for reliability. I then staged my 2 AEM’s. So you basically have 1 AEM400 and 1 low amp pump going. The amp draw isn’t much. I used factory fuel pump wiring on the surge pump. And 10g wiring with 30a relays for each pump. I like to use TPS to activate the second pump. But you can do it anyway you want.
I’ve never run DBW setups. Can’t be of any help there.
The 220lb injectors are rated at 43psi. So dropping to say 30 is going to turn your 220lb injectors into 183lb injectors. Still plenty of injector for most. The issue with large injectors is that its hard to get the pulse width low enough to idle at a stoich AFR. Lowering the pressure actually helps with this.
https://www.witchhunter.com/injectorcalc1.php
Downside of Lower pressure is poor atomization (crappy spray pattern). That’s why the industry standard went from 43 to 58. But when you are working with Bosch 220lb injectors (CNG injectors) they are basically squirt guns. They have no real spray pattern.
I don't run a filter pre pump. The AEM units have screens on the inlets. and I didn't run any pre filter on the 4303. Not saying thats the best practice. But Its what I do. Never had an issue. I also don't put hundreds of miles on my cars.
https://ls1tech.com/forums/forced-in...er-report.html
This is the WIX unit I used on my last build. 2 AEM400's feeding it then the two outlets to the regulator and a single out from the regulator to the rail.
https://a.co/d/23MEz5o
Yes they make socks. but the AEM has filters on the inlet side anyway
