4L60E questions
In all seriousness, when they're stock it's a roll of the dice, but they can be built to live behind a decent amount of power for not a ton of money.
A friend of mine had his built to handle about 600whp with 2.73 rear gear and even with that steep gear it held up really well.
He ended up selling it to another turbo f-body guy who is still running it to this day.
I'd pull it and have it upgraded because if you break it, you may have to replace the whole thing.
Everyone will have their opinion based on their experience. My experience wasn't good, ever.
A 4l60, "MAY" be able to hold that kind of power if built properly, but in my experience, how long will it live? If you want to spend money on something that is going to be a item that needs serviced every year or two, then a 60 is the way to go.
If you physically look at the clutches in a 60 vs the 80, well that will tell you all you need to know. Building them is about the same money. The converters, about the same money. It's really just a matter of spending money and planning. I hate spending money on the same thing over and over, and I did a 60 3x before I bought and built a 80. The 80 has been together ever since. Just my opinion based on my experience.
When it breaks im likely to go with an 80e, but I’ll run it as long as I can.
I have a basically stock 80, that is dual fed. And when it has 700-800hp hitting it, I'm not worried one bit, because I've done it before.
I just know I spent $ 3x on a 60, and I may as well have lit it on fire. I wasted time and money and frustration, when if I had just thought it through, I would have just bought the 80 to begin with, but "people" said how big they were, how heavy they were and how horrible the gearing was.
The trans fit in my truck no problem. They are heavy, I'll say that, but the trucks 60' is as good with the 80 as it was with the 60.
If my memory is correct the level 6 was just over $3000 and has lasted over 4 years now. I started with a boosted sbe, then added a built ls3, and then recently replaced the D1x with an f1a-94. It doesn't owe me anything at this point. I ran a 60 previously from FLT which was a level 5 behind a 408 with a 150 shot for several years without issue. Sorry about your luck with them, but in no way am I claiming a 60 is better than an 80.
I specifically said I will go to an 80 whenever the 60 dies, but I will run it until it breaks since that is what I already have.
RPM makes a level 7 and a level 10, but yes, they get pretty pricey.
He will have to do some cutting to make the 80 work in a GTO, but if he plans on making ridiculous amounts of power then the 80 right from the get go might make sense for him.
Unless you're restricted by the available space, a 4l80e is ALWAYS a better choice than a 60e when it comes to making power.
Additionally, I spent half as much money building my TH400 with converter for 1,200 hp as I would have spent building a 4L80E.
nevermind ebay says 2004 gto 4l60e i dont know why someone would tell me that.
