Dart 402 block, 10.5 compression, Tooley Trick Flow cnc heads, F1a blower..
Like mentioned it's the tune not the boost level. Too much timing for the combo and yes you will have issues.
The following users liked this post:
stage274 (06-18-2024)
Had this set up on the last motor. Blocks all the hot air from the top and lets the blower breathe. Cold air is taken from the bottom.
Hot air is blocked from the top.
