Proform brushless cooling fans?
John has his double under driven and it still works, I know guys on here who way over spin theirs and have no issues with output at idle or high rpm (7,000rpm+).
I haven't been that lucky with alternators/batteries, so I just ponied up and bought an expensive alternator and battery because I was tired of dealing with it.
My last 4th gen F-body had a truck alternator with a 25% under drive crank pulley and it seemed to work fine shifting at 6,000-6,500rpm.
On my last car, a 02 Camaro SS I went through six reman alternators before I picked up a reman Escalade alternator and never had another issue, the car actually ran better too.
The truck case being larger than the smaller F-body case has more output at idle and in most cases will fit in the same location as the small F-body unit with a little massaging.
The JS truck case unit has the same diameter as the truck case but is a little longer so might be more challenging to package but well worth the extra power.
If you can fit a truck alternator in there, then that would be my move.
I was considering using one again but wanted output over a wide range and didn't want to pulley down and possibly lose output at idle or over spin it and it fail so I landed on a JS unit.
EDIT: Dennis just text me and informed me the blades are not interchangeable. So hes sending me a complete s blade fan assembly. Still will keep you guys updated.
proform - 2087cfm
flexwave - 2031cfm
spal 16” 500w - 3511cfm
My brain says that if I'm getting 35mph through the same radiator that I was getting 19-22mph that the CFM doesnt just jump 400cfm going up 13-16mph. The 3,500 number feels right when you feel the air this thing is pulling that just doesn't make sense when SPAL rates them at 2,450.
I drove mine out to my buddies' house yesterday to store for a few weeks while the wife uses the garage to stage her yard sale.
It was about 82 degrees so not bad, running down the highway at 55mph, turning 2,500rpm, coolant temp got up to 194 degrees and voltage was at 13.7 the whole way with all the fans running.
As soon as I hit the off ramp it went down to 180 by the time I hit the stop light.
Anyway, a great unit you'll be happy with.
this fan is negative PWM as fast is like 5-10% and slow is like 80%. What’s weird is I think around 85% at 100hz the fan stopped chugged and spun in the opposite direction becoming a pusher. Idk what’s up with that so I started at 80% and worked my way down to full speed.
Started out at 80% and that’s 2.5 amps/36w and 925ft/min
40% is 22amps/279w and 2243ft/min
10% is 73amps/842w and 3089ft/min which ends up at 4,447 CFM pulling through the core basically. The speed was 35.1mph which is basically the same as the 16” but given the 2” of extra blade and a slightly bigger hub the fan easily pulled 1000cfm more through a core.
Andrew
I know that Spal has certain frequency/duty cycles for testing and diagnostics but I've never heard of one switching directions before.
P.S. to be clear, I'm DD this car for the time being. This isn't just a run to the grocery store or the gym type of situation. I work almost 30 miles away and traffic is bumper to bumper most of my drive to and from. usually takes an hour to and hour and 20 mins to get home or to work. So in my opinion, they are being tested in pretty hard conditions.
