Proform brushless cooling fans?
Old Jun 7, 2024 | 08:50 PM
Miata khalifa's Avatar
Originally Posted by Kfxguy
why is your voltage dropping? What kind of vehicle?
Not too sure just yet.. everything was fine before. Just went out for a drive and it over heated. When one fan kicks on the other kicks off. The short time that both are on at the same time, my voltage drops to 12.5ish. shouldn't be pulling anymore amperage than my last spal fans I just replaced. 2 separate 30 amp relays with 10g wire.
Turbo LS Miata, rear mount radiator. 105amp alt.
Old Jun 9, 2024 | 11:20 PM
Kfxguy's Avatar
Originally Posted by TrendSetter
link went to eBay but didn’t show anything
Old Jun 10, 2024 | 06:50 AM
TrendSetter's Avatar
Go on eBay and search for ‘pwm signal generator’
Old Jun 10, 2024 | 08:32 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
fkx, what dimensions are you working with?
I have multiple contacts liking the factory 19" 6th gen Camaro fan.
Old Jun 11, 2024 | 01:34 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If he has a stock size radiator, no way a 19" fan will fit. Radiator is too short on the 2004 GTO.
Old Jun 11, 2024 | 02:36 AM
Update. Talked to pro-form today. They're currently working on a recall and hopefully will be solved by the end of the month. The thermal safety is cutting the fans off at 185 instead of 250. Hopefully they get it all figured out and I can use these fans still 🤞
Old Jun 12, 2024 | 08:32 PM
Kfxguy's Avatar
28” x 18.25” is how big my shroud is.
Old Jun 12, 2024 | 08:33 PM
Kfxguy's Avatar
well that ain’t good.
Old Jun 12, 2024 | 08:34 PM
Kfxguy's Avatar
Got my 16” fan in today. The about of air it moves and the power is absolutely insane. It will easily levitate itself off the table just hooking power to it. I immediately ordered the other one.
Old Jun 12, 2024 | 09:34 PM
Hopefully you got a good one. I talked to them again today. And he said they're still selling them. About 600 sold so far. Not everyone is calling back, but a ton of people are calling and complaining. Said he was getting beat up over it. I could hear it in his voice too when he answered. He promised me a set of updated fans, hopefully by the end of the month though. 🤞
And yeah they move a **** ton of air when they're on. I'm really hoping these work out..
Old Jun 12, 2024 | 09:43 PM
Kfxguy's Avatar
ugh. Not good for me to hear. I like in the super hot south Louisiana. I can’t have fans leave me stranded. I wonder if I should request a set of updated fans too. I don’t want to take any chances.
but yea, the amount of air it moves is unfukinbelievable! If these work out, I don’t see it having any issues over heating
odd thing is in the instructions it states it’s not pwm compatible with anything else but its own controller. Hard to believe that when it’s just a pulse and full power is just sending full voltage to the green wire. I wonder if their controller actually puts out variable voltage instead of frequency. If that’s the case, I could possibly incorporate two speeds. I’m going to add a resistor to the green wire and see what happens.
Old Jun 12, 2024 | 09:47 PM
  #32
Kfxguy's Avatar
On a side note, I’m a total nincompoop. I made the shroud for the condenser side of the radiator. What a dope. Smh. Well good news is, I cut the tabs off and I can make some more and weld them in the right spot. The gto radiator has hooks on each side of it for the fans and condenser. I wasn’t thinking about it very well. Roll eyes at myself.
Old Jun 14, 2024 | 02:05 PM
  #33
I feel you, I'm in SC. It's blazing hot here right now. They're about to recall all of them if I'm not mistaken. So I would just check back at the end of the month if you don't have issues before then. Assuming you only bench tested and haven't ran them on a hot radiator yet? That's when they shut off. Sales rep said they ran one for 8 hours straight but never tested them on a hot radiator. Which sounds kinda sus 🤷. Idk though. I asked about why the controller says pwm, if they're not pwm capable. He said he didn't know why that controller even says that on it because it just controls the duty cycle. I asked if I could still control it through the Holley, and he Said as long as it's over 110khertz it "should" work. I thought about the resistor thing too. Interested to see how that would work.
Old Jun 14, 2024 | 02:41 PM
  #34
Kfxguy's Avatar
well maybe I need to put a heat gun on the motor to test it. How long does it take to shutdown?
I forgot to try the resistor last night but if it’s varied in hertz, I may need to come up with something else.
Old Jun 14, 2024 | 02:58 PM
  #35
Kfxguy's Avatar
idea. Get the controller they sell. Install it, turn the speed down some on it. Then use a relay to break the circuit to the green wire and return the green wire to full 12v for full speed. You’ll need a 2 speed circuit for this which my gto has 2 speed fans. Little rewiring on my part and I think I can do it that way if the resistor doesn’t work. If I’m not mistaken, pwm just makes it see a lesser voltage.
I found this:
PWM meaning is effectively chopping off parts of the waveform to reduce the average voltagewithout affecting the base frequency of the signal. Increasing the period when the voltage is 'off' reduces the average voltage, hence the power.
Old Jun 14, 2024 | 06:09 PM
  #36
I found this:
did you ask ai or something? lol thats describing how you dim ac power. since ac is a fixed frequency (60hz in north america) you have a circuit that watches for the 'zero cross' which means the ac power wave(which is a sine wave going from full positive to full negative) hits that zero point of going from positive to negative or vice versa, then clip it by turning off for a period of time relative to the overall period/2.
pwm in our context is similar but is a square wave rather than sine wave and the frequency can be whatever we want it to be. some devices care, some sorta care. i have a device that i designed and sell that just needs anything more than about 150hz and it calcs the duty cycle from there. the duty cycle is what controls the 'amount of power' which is the percent of time on vs time off. theres no negative voltage like in ac. the frequency usually is driven by what you are powering. if its just a signal to another controller, its less important than if youre dimming a light or slowing down a fuel pump or controlling a waste gate solenoid.
for a brushless motor per the context of this thread, its just a signal to the internal controller that handles the current, so anything that makes a low current, (most likely) active low square wave will work. i have one of those boxes from ebay that i posted about earlier. its less than $10 and works great and is literally the exact piece proform is selling for $40.
Old Jun 14, 2024 | 06:11 PM
  #37
they are stupid or lying.
no, thats a $8 ebay controller that puts out a pwm square wave.
Old Jun 14, 2024 | 06:16 PM
  #38
the fan instructions say:
Green Wire: Only for use with PROFORM mul>speed digital controller, part no. 67039 (op>onal) OR wire it
in with the 12 Volt (+) wire. DO NOT REMOVE THIS WIRE, IT MUST BE USED IN ONE OF THE TWO WAYS
MENTIONED ABOVE.
and
THIS FAN IS NOT COMPATIBLE WITH PWM VARIABLE SPEED CONTROLLERS
what they mean by pwm variable speed controllers would be one you use with a typical DC fan like the C6/Fusion controller we have a big thread about here, which are made to pwm the full load of the fan motor. these brushless fans have their own controller like that built in.
the green wire is a signal pwm input with a pulldown resistor meaning it internally grounds itself and needs a positive 12v signal (sorry terminator x dudes) to activate. either a +12v pwm (square wave) signal at 110hz or just straight 12v for 100% on.
Old Jun 14, 2024 | 08:21 PM
  #39
Kfxguy's Avatar
you’re awesome. Thanks!
resistors did not work. Not surprisingly.
edit. Just ordered one. Be here Sunday
Old Jun 14, 2024 | 08:57 PM
  #40
Happy to help. Im sure it’s hard to tell but electronics are a bit fun for me
