Proform brushless cooling fans?
I mocked it up, had to make some changes to the plate but I Got them mounted. I have much more room now and it’s much easier to get in and out. I mounted the 16” on on the passenger side because more air can escape on that side vs the driver side. I have not cut the holes in the plate yet, I had to run to home dept and pick up some jigsaw blades for that. I’m also having a problem with wiring. I cannot figure out what wire I can use as a trigger. Originally I thought I could just make the low speed and high speed come on at the same time and just find 12v at the plug, but the fan plugs are three wires do it doesn’t work that way. I checked the relay terminals at the under hood fuse box. No luck. I then looked up a wiring diagram and it showed three relays in the circuit and I only see two. I really didn’t want to run a wire from the ecm if I didn’t have to, it’s inside the car. Ugh. I’ll have to do some more research.
who have you been talking to over at proform? I’m gonna give them a call tomorrow.
I just called. He’s out till tomorrow. I’ll try him again. In the meantime I talked to the seller of the 16” and he said I can return it to him for a refund but I told him I’m going to wait till I talk to proform. The seller of the 12” hasn’t responded yet.
I feel you, I can't make it to sct in NC Thursday cause of this.. just wanna enjoy my car. My 200 dollar radiator worked fine, but now my 2500 dollar set up sucks lol.. of course mainly cause I moved it to the back. Heat wrapped the hot side today, just went for a cruise and don't see much of a difference really. Ready to have some air moving. Tempted to buy some expensive spals, but probably not even worth it.
I use a 160 thermostat with fans on at 179. Car typically runs between 180 and 183. It doesn't get as hot up here and I'm Procharged so my under hood temps are super cool. I have a vented 05 hood and removed the seal at the back of the hood. I also make sure air is directed through the radiator and can't find a path around it. I wrap my headers and run e85 with meth injection. We had a 95-degree day this last week that was way above our norm for this time of year, so I went for a long highway drive. Couple 7200 rpm pulls then went right into town for some stop and go driving. I then let it sit running in my garage for a while. The hottest I could get it was 185. I've noticed my under hood temps are way cooler than my friend with a turbo. You can tell the difference is obvious just popping the hood after driving a while.
that whole assembly with shroud and two fans is only $170???? No frigging way. Ida bought that long ago had I known about it.
edit. I think that’s just the fan. The shroud bare is $219 which still isn’t a bad deal.
Really surprised to see Miata having issues with SPAl, but I'm curious what ya mean by the cheaper? Non brushless?
