Low boost 5.3 octane and meth
Quick question about a manual boost controller. I heard the manual controller requires pre TB compressor air? Why can't I use the current manifold line I have run to the back of the intake? I Tee'd off the manifold and ran a line to the BOV and a line to the wastegate. I was thinking I could splice into that line and add the manual controller which I could run to the top of the gate. Thoughts?
I’d also think it kind of depends on the gate control plumbing you use. Unchecked vac to the upper chamber could open the gate during cruise.
I prefer to have as much pressure as possible for control to ensure the gate stays closed until I want it open. I don’t see that causing unstable boost targets. I run 100%DC to the top port only until desired boost pressure is reached. Then vent the top to the bottom port to control w a 3-port mac valve.
Now onto what I just datalogged today. I only had one onramp to log on my way to work, 52*F out so I was being careful not to go WOT as the new ultimate summer tires are still breaking in. I went to about 70% TPS according to my log, car felt faster and feels real strong up to like 4k and then feels like its tapering off. I checked the logs at work a min ago and heres what I found. Remember I have about 10psi cracking pressure on the bench with both 4.6 and 6.2psi springs installed.
I had 2 boosts logged back to back in the same run as I let out as I was already doing 100+ and tires felt alittle loose.
First Blip
4800rpms
70% TPS
125kpa
87*F MAT
11.86:1 AFR
Second Blip
4500rpms
70% TPS
129kpa
90*F MAT
11.68:1 AFR
Logs show a max boost of 3.9psi initial on boost and tapers off down to 3.1-3.2psi. So Going from 4.6psi spring to 10psi total I'm only seeing 3psi boost WTH. You can feel the car kinda like nose over as the boost lessens about 1lb. With the #5GPH snow nozzle I'm seeing MAT temps at the start go from 95-85*F and then pick up again after I let out. While driving around MAT never got higher than 150*F and while cruising (40 min drive of city 40mph and lower) temps are 130's maybe 140*F.
At this point I think the MBC sounds like it would make the most sense. Now referencing the intake manifold vs compressor and how do I plumb it? I would think that I would need to double the spring pressure to net 6psi of actual boost.
I have a turbo build thread on the vette forum. https://www.corvetteforum.com/forums...5-3-build.html
it’s a 78, I got about 2k in the whole turbo setup, from turbo to exhaust bends.
I’ve been struggling with boost at the moment. I had 15lbs of spring in it and only managed 4.6psi. The car is much quicker now tho. I really only want to build 6psi as I figure that will put me around the limits of the build 700r4 and the batwing rear. Yes the car is a 78 but 40 years ago was in an accident and the guy converted to a 80-82 front end, rear bumper and they put the 80-82 rear end in it. Traction is now a problem even with the new 18x9.5s and 275 ultra summer tires on all 4 corners.
Outta make a great cruiser for sure.
Yea, I used all cheap stuff, Turbo manifold was like $90, Ebay SS block hugger headers, Amazon Stainless pipe and bends, $170 summit WG, Turbo I got used off FB... I already had the 60lb Deka injectors. You can still do some things cheap lol. Its def cheaper than building a 383 to put in it.
53% TPS
150 MAT now 100-114*F
283lb/hr now 290-295lb/hr
6.4psi
22.3* timing
5221 rpms
Before intercooler
Basic calcs put me at 470hp at .6 BSFC and 283lb/hr
After intercooler
490hp at .6 BSFC and 293lb/hr so thats a 20hp gain with just dropping IATs by the 40 degrees.
