New stock block record
Old Oct 5, 2025 | 04:56 PM
BCNUL8R's Avatar
Default New stock block record
I saw this on facebook. He pulled the big block out and went to the stock block LS combo only a couple weeks ago.
Old Oct 5, 2025 | 05:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yeah I'm going to update the list pretty soon. He's running a sleeved LC9.
Old Oct 5, 2025 | 05:37 PM
GMCGreg's Avatar
Impressive!!
Old Oct 5, 2025 | 07:14 PM
C5_Pete's Avatar
The lines get blurred in “stock block”…
That said, 4.06 is a baller pass for sure!
Old Oct 6, 2025 | 04:36 AM
Vokes's Avatar
This is nice
Old Oct 6, 2025 | 10:14 AM
NicD's Avatar
7 Second Club
Ahh the old stock block record, with thousands and thousands of dollars of work done to it to make it not "stock" anymore.
Old Oct 6, 2025 | 10:59 AM
Sleeved block isn’t a stock block…I wonder what part of the “rules” allow you to do whatever you want to your stock block, in order to not make it stock any longer? Billet and pinned mains? Does deck height matter? Lol…
Old Oct 6, 2025 | 11:12 AM
BCNUL8R's Avatar
Feel free to delete thread if you feel im being dishonest.
my mistake I thought a resleeved oem block was still considered stock block since it’s not an aftermarket block.
This would also make what Steve morris is doing completely useless as his would not fit the stock block rules then either if resleeving is not allowed.
Sorry for the misunderstanding.
Mods please delete thread.
Old Oct 6, 2025 | 11:29 AM
NicD's Avatar
7 Second Club
The point is that it's 100% up for interpretation, and everybody has a different definition which makes the whole "stock" block record pretty meaningless IMO.
Old Oct 6, 2025 | 11:47 AM
LS1Tech Co-Founder
Beater's 4.060 is impressive in every way, he's now #19 on the all-time quickest in the 1/8th section of the LSX Record list.
Stock block is a bit of a spectrum. Capizzi's car has stock sleeves, 1/2" head studs, pinned mains and is hooped. Stock sleeves limit the bore size obviously.
Beater is running Frankenstein LS7 style heads on a 400 ci sleeved engine, not filled, but no water.
Old Oct 6, 2025 | 12:21 PM
BCNUL8R's Avatar
No worries you can delete the thread. It wasn’t my intention to disrespect your friend.
After the Steve morris thresd I got the impression that resleeved oem blocks were still considered stock block.
now I know only untouched oem blocks count as stock block. Lesson learned and I will not forget. Someone should probably tell morris to stop wasting his time on his stock block project because his records will not count either.
Old Oct 6, 2025 | 12:22 PM
Kawboom's Avatar
I mean, its very impressive, and putting aside the sleeved block for a moment, if I were to put a "stock block" in a 1800 pound Top Dragster chassis and run a bit quicker would I be the record holder? I wouldn't think so.
Stock Bottom End is a better metric, in my opinion, but even then it's fuzzy where the criteria begins and ends.
Old Oct 6, 2025 | 12:26 PM
BCNUL8R's Avatar
by the standard presented here opening a sbe to gap rings pin mains or change rod bolts would make it no longer a sbe.
Old Oct 6, 2025 | 12:40 PM
Kawboom's Avatar
maybe, but I would let you gap or even replace rings.
Old Oct 6, 2025 | 01:01 PM
BCNUL8R's Avatar
You would? So who makes the rules for these records? Or does it just depend who we are friends with?
Old Oct 6, 2025 | 01:03 PM
Kawboom's Avatar
It's like what U.S. Supreme Court Justice Potter Stewart said, "I know it when I see it"
It's subjective, which is why it's not an official race class or something. Just doin it for the sake of doin it.
Old Oct 6, 2025 | 01:21 PM
slowride's Avatar
I always just considered it to be stock sleeves, block etc etc. I mean sleeving a stock block is as expensive as a LSX or Dart block for the most part so unless you need the weight savings I don't see how I'd stick to the smaller engine. But this topic is just like the street car topic and everyone will just argue forever as to what THEY think it is lol No reason to delete the post though it's still badass and he will probably go faster.
Old Oct 6, 2025 | 01:37 PM
LS1Tech Co-Founder
I'm a purist, like Ed said above I view a sleeved block as a modified stock block, so it's an asterisk record to me. I do notate on the list if someone is running a sleeved block.
I've heard that Steve Morris is cutting up the deck off and replacing them, that's not stock block by any stretch.
Good conversation.
By the way, the mods I've seen folks do over the year to stock blocks are:
-Hoops
-1/2" head studs
-Pin the mains
-Probably there are people who have dry decked the blocks, welded up the water passages, to smaller. LME used to do this for LSX blocks, so maybe stock blocks too?
-Kurt Urban once shared pics of cylindrical inserts that were pressed or machined into the corners of the blocks in the water passages. Any have those pics handy? I could ask him for one. I haven't seen anyone do this in a long time.
Old Oct 6, 2025 | 01:57 PM
ALL ULL C's Avatar
It is an OEM cast production block for a GM vehicle, no two ways about that. There after, have a ball with your micro-world records on every possible change you can make to said block. Whether that is sleeves, hoops, 1/2" studs, oiling mods, pinned mains, pinned mains made from different material, solid deck, etc. Doesn't change the fact that it started life never intended to do the things that some really smart people are doing with them.
Old Oct 6, 2025 | 06:47 PM
LS1Tech Co-Founder
Agreed, GM folks never imagined that someone would take an engine out of a Chevy Avalanche and run 7s with it.
But sleeving for a bigger bore is where I personally draw the line. Like someone already mentioned you are at the cost of an LSX block or a Dart iron block.
