Bigger intercooler results!
12 Second Truck Club
Just finished swapping out the stock ATI intercooler with a big griffin just like Pro stock Johns.
I did a log with the old intercooler 5 nights ago, results were--
DA-7671 feet (ouch!)
Ambient- 79 degrees
IAT- went from 91.4 to 149.0 0-100mph gain of 57.6 degrees
4000rpm(launch)- 22.32 lb/min
4800rpm(bottom of shift)- 35 lb/min
5800rpm(shift point)- 43 lb/min
Saw 10 psi
Tonight with new intercooler--
DA-7005 feet
Ambient-73 degrees
IAT- went from 77 to 104 0-100mph gain of 27 degrees
4000rpm-- 27.12 lb/min
4800rpm-- 42 lb/min
5800rpm-- 54 lb/min
Saw 11 psi
I gained (approx)
50 hp at launch
70 hp at the bottom of the shift
110 hp at the shift point
and 1psi
These numbers are what I used to see in the winter when it was 20 degrees outside and the DA was in the 3000 feet range!!!
Man, that ATI intercooler must be restrictive!!
I'd say this project was a HUGE success!
One weird thing, my air/fuel went from 11.7 to 1 to 10.5 to 1 with no tuning changes. Only change was the intercooler swap. Anyone have any idea on that one?
Ambient- 79 degrees
Saw 10 psi
DA-7005 feet
Ambient-73 degrees
4800rpm-- 42 lb/min
5800rpm-- 54 lb/min
Saw 11 psi
I gained (approx)
50 hp at launch
and 1psi
The more efficient you are the richer you will run. I have noticed this with a wideband. I would add timing and my A/F numbers would change to be richer. I'm am not 100% sure why as there are many things that can cause this, but I think running more efficiently you run richer.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Oh ya, I forgot in the last post
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by BIGBOS
I'm still waiting on my griffin identical to yours, I hope to increase the timing and see a boost increase ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I guess it shows what good a high flowing intercooler can really do.
Nice! I am at about the same DA's(7600-8000ft) here in albuquerque but with hotter outside temps. I hope to see similar results from my FMIC. Today is the day to take it out logging. No rain, little humidity and a rather cool 92 deg's out.
Thanks for posting this up.
J
J
LS1Tech Co-Founder
We had logging problems so I'm not sure I have the info, I will check today and post it up.
IMO many FI kits do not offer what I would call the best or ideal intercoolers... After all, these big FMICs are not what most folks are wanting. But when you start to look for advanced levels of performance you start to evaluate your parts and look at the weak links.
Originally Posted by NA$TY-TA
This is great info for those of us about to do this. Not only do we pick up airflow (PSI) we become richer and able to run more timing pickig up more power that way also. Im stoked mine should be here tomorrow.
Kyle
Kyle
If my intercooler restricted 11 lb/min of air at 54lb/min, I can't imagine what you guys that are already up around the MAF max with the twins are going to see!
you guys need to run a smc or alky controll alky kit ! will drop temps to air temp or below plus you can run more timing and more boost just like race gas. I run it on my 89 TTA with T-70 DBB run 26 psi with 26-30* of timing with the stock TTA/ grand national I/C PM for mor info
