Anybody have problems with their Autometer guages?
My fuel pressure gauge freezes about every other time I start the car. When I see my gauge stuck, I turn off my car and restart it, and that will get the gauge working again. I think sometimes it doesn't go through its self-check at start up
My boost gauge drops to vacuum every time I shift. If I go through the gears fast or semi-fast, the gauge will not go back into the boost section until I pause in between shifts. If I go through the gears slowly, and slowly ease into each gear, the boost will come back after every shift. I thought I was possibly having belt slippage, but I recently installed a SDCE 8-rib set up and I am still having the problem. However, I don't think I am having belt slip because the cars pulls like a ***** even when the gauge goes into vacuum after a fast shift. Anybody else have similar problems?
which FP gauge do you have? they recalled the partial sweep gauges a while ago.
My gauges do not say what model they are. They just say Autometer on the face. I will have to go home and look at the boxes they came in to see what model they are. They have black faces on them if that helps.
I have a mechanical boost gauge and an electric fuel pressure gauge.
so I hooked up to a "true switched" power wire straight from the fuse box, haven't had the problem since.. I suggest you check that first.. lemmie know if it works.
and he has issues with it sticking at 10psi. I had to actually pull it out of the pod and disconnect the molex plug for it to reset. they recalled the partial sweeps.
and it could just be you tapped the wrong wire.
I have the full sweep fuel pressure gauge wired to the fuse box, but it sounds like I have it going to the wrong fuse. I will rewire it to where "Got-r-done" suggest.
Thanks for all the input from everone.
Now I just need to figure my boost gauge problem out. Again last night, I rolled through the gears and paused a bit between shifts, the boost gauge would go back into boost after each shift. However, if I got on it going through the gears, soon as I shifted into second, the boost gauge would go into vacuum and stay frozen there until I let off for a little bit. Its as though the needle freezes in vaccum and doesn't come alive again until I let off.
