Project Update - D1SC Home Kit
Old Aug 6, 2004 | 09:53 PM
NoGo's Avatar
Default Project Update - D1SC Home Kit
Hello,
Pretty excited about how things are turning out with my home/shop kit, so I figured I would share.
(prior post) https://ls1tech.com/forums/forced-induction/146845-home-built-d1-system-pics.html
The car made it onto the rollers for the first time today. I'm still in the process of ironing out a few bugs (getting bigger injectors etc...). The air fuel is still a little lean and timing is still set safety low (16).
The setup:
Home Built D1SC FMIC kit.
383 All-bore H/C
The results:
665 HP
622 Tq
The fuel system is pretty muched pegged at 4800 rpm (50 lb injectors) so the peak power is premature at 5800. Once the bigger injectors are put in and I can get the a/f down to something reasonable and the expected peak power/boost at 6300 I am expecting to get near/over 700.
Old Aug 6, 2004 | 09:57 PM
thechef's Avatar
Moderator
WOW kevin thats just awesome
Old Aug 6, 2004 | 10:13 PM
Mark C's Avatar
Who's going to tune it for you?
I hear that's the key.
Old Aug 6, 2004 | 10:23 PM
-=Merlin=-'s Avatar
Is this still on the 4-5psi?
Very nice power!
Old Aug 6, 2004 | 10:37 PM
NoGo's Avatar
This is running 16 psi now
Old Aug 6, 2004 | 10:38 PM
NoGo's Avatar
I don't know, they said there was a pretty good tuner at Eastside.
Old Aug 6, 2004 | 10:41 PM
-=Merlin=-'s Avatar
16psi and you aren't having any belt issues? This a 6 rib?
Old Aug 6, 2004 | 10:44 PM
ls1hybrid's Avatar
pump gas? or mix? nice numbers so far
Old Aug 6, 2004 | 11:06 PM
NoGo's Avatar
The drive system is now an 8-rib SDCE (6 rib slipped too early.....bummer).
93 octane pump gas.
Old Aug 6, 2004 | 11:12 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice. I have a feeling I should one day try to see what I can make on pump gas.
Old Aug 7, 2004 | 12:26 AM
69firebird's Avatar
any pics?
thanks
ed
Old Aug 7, 2004 | 09:23 AM
NA$TY-TA's Avatar
93 octane pump gas.
That right there gives alot of us hope to what we are wanting to do with our kits. I am wanting 14-16 psi and i should see it with my new FMIC and a 3.2" blower pulley from RRacing. Shifting at 6600 rpm i should see what you are seeing. I hope my 60# injectors are enough. Is that what you are going to get?? the 60#'s or bigger? Awsome man keep us all posted on what you do.
Kyle
Old Aug 7, 2004 | 09:24 AM
NA$TY-TA's Avatar
Oh are you maxing out the MAF???
Old Aug 7, 2004 | 09:52 AM
NoGo's Avatar
I am looking for something bigger than a 60# right now. To size everything properly I really need an 85# injector. I thought I read something about a 75# the other day, which I could get to work.
The problem with the superchargers is that the equivilant cylinder HP that we are dealing with is upwards of 900 HP at that power level.
RWHP + Supercharger Loss + Drive Loss
700 HP + ~150 HP + ~50 HP = 900 HP !!
Finding a high impedence injector that will feed 900 HP is tough.
The MAF pegs as soon as the bypass closes .
Old Aug 7, 2004 | 11:59 AM
NA$TY-TA's Avatar
So what would 60# injectors be good for HP wise at 58 psi FP?? I would be happy with were you are now 650rwhp...... Im still new with tuning after the MAF Max's out..... Does anyone know if Jayson at MTI can tune around the MAF for my next tune when i go back with my FMIC and 3.2" blower pulley.?? I know you can tune...............
Kyle
Old Aug 7, 2004 | 12:24 PM
frcefed98's Avatar
Looking Good Kevin.
J
Old Aug 7, 2004 | 01:07 PM
Ken G's Avatar
Congratulations! It's time to drive that thing around and enjoy all the hard work.
Ken
Old Aug 7, 2004 | 01:43 PM
SPRSPT's Avatar
Hello,
(prior post) https://ls1tech.com/forums/showthread.php?t=146845
The setup:
383 All-bore H/C
The results:
665 HP
622 Tq
Nogo rips by the shop and I look around to see if Mavrick and Goose are hangin out...lol...The thing sounds like somethin out of Top Gun...It just sounds sick....All blower/blow-off quiet exhaust....
Old Aug 7, 2004 | 04:57 PM
CHRISPY's Avatar
GREAT NUMBERS!!
What compression is the motor and what cam specs?
How lean were you going above 5800rpm?
Old Aug 7, 2004 | 05:46 PM
BIGBOS's Avatar
I think the 60's can go far, but if all else fails, I'll get those 70's that wilkinsion is running
