Intercooler questions .
Sup guys , I would like to know some info on intercoolers . This is my intercooler :
http://community.webshots.com/photo/...52676319ZyZSZf
What i would like to know is this , probably this intercooler would flow like 1200 cfm and my F1 blower is capable of flowing 1500 cfm ( so 1000 hp ) . So does this mean that i could only make like 800 hp because the intercooler can't flow more cfm or does making more boost means that it can flow more cfm . I Ask because i see some twin turbo intercooler on cars that made 1000+hp and doesn't look bigger or much bigger then mine . From looking to my intercooler it looks like it cools less then others intercooler ( like the griffing ones ) cause it doesn't have too much core but flows more because of that . I am getting my alky control (progresive alcohol injection kit ) next week so i'm deciding that if the intercooler is small for my setup i would be using only the alcohol injection and get all the cfm out of the blower . I'm not good explaining this cause i'm not an english speaker . So any info on intercooler vs hp vs boost , or what diferent type of intercooler should affect cooling or hp should be realy aprecieted .
Thanx
Geomar
Thanx
Geomar
Thanx
Geomar
Thanx
Geomar
Ie. Your intercooler will flow 1200 CFM with a 2 psi pressure drop.
If you push more flow through your intercooler you will have more than a 2 psi pressure drop. It isn't the most efficient way to operate, but I don't think it is going to hurt your setup that much. FWIW, you very rarely get the full 1500 CFM out of the blower anyways.
That intercooler is Machperformance custome ones . They have almost the same dimensoins as the procharger 3 core (race )one one that flow 1500 cfm (950 hp ) but the dimensions on the procharger one is 27x15x3 and mine is 27x13x3 (both have 3 inch inlet/outlet. The core size is the same the only diference is that the tanks are a little smaller . How much should that affect flow ? See the procharger intercoolers here : http://www.procharger.com/intercoolers.shtml
thanx
thanx
ok , so the when they say an intercooler flow 1000 cfm doesn't mean you can't make more hp out of that intercooler rigth . Its just not efficient beyond that right ? I tought that when using an 1000 cfm intercooler it doesn't matter how hard you press it , it just would flow 1000 cfm . I think this is a good topic cause i searched around and didn't see much info on this and how intercooler size and design affect hp .
Now that we talked about this , why does people chang there ati twin intercooler when you can push more and more . You know what i mean ? Or is there a point that it can't flow anymore .
Thanx
Geomar
Thanx
Geomar
LS1Tech Co-Founder
I guess it depends on how much power you are trying to make. If you want to make 700-800rwhp you might benefit from an intercooler rated for more cfm like mine. I know a few folks who have upgraded from the ATI sheetmetal intercoolers to other solutions but they were pushing 700-1000 hp.
we are still looking where i can get an good trans ( th400 or powerglide ) in miami or florida cause shipping would be alot less . I was thinking into rossler but its too far . Or probably when i go to live to housten texas in 2 weeks i will look around there . I will only be there for 1 year .
I went alot of times to the track and i was the fastest daily driver truck in aruba which was low 12s . That was on an build 4.3L v6, with an modified 350 (cutted and shortened to fit my v6 vortec heads ) and only running 150 shot nitrous . With 225 shot I couldn't make a good pass because of fuel puddling and huge backfires thrue the intake . With 225 shot it should had run atleast mid 11s cause even with 150 shot the 4L60-e ( build one ) didn't like the 2-3 shift . And that is with me using yank manual push botton and full line presure . I had to let them rebuild my trans twice with good parts and transgo shift kit with no luck .
If i am able to run low low 10s i would be the fastest street legal car in Aruba .
Geomar
Geomar
Intercoolers that are rated to say 1000 CFM will flow a lot more than 1000 CFM, but they will be declining in efficiency when you start moving that much air through them. IE: We run a Precision "600 Horsepower" intercooler in a friends Integra, even though he's making over 600 WHP which is a ways beyond the peak efficiency rating of around 600 horsepower.
Geomar
Geomar
Thanx , I just hope it holds . I think i would need huge boost to get the numbers i want with this motor/heads/intake to have a problem with the tanks .
Geomar
Geomar
