Turbo 403ci with hyd cam= 1329hp flywheel
what kind of torture technique is this !!!
WE NEED MORE INFO !!! i have 3047504362906 questions about that motor, so pleeeeeeaaaasssseeeee give us more info. ( some pics would be nice too)
Awsome Kurt....... on a side note... will you be at Thunder?? What will you be driving this year if you are going? Ill be there.... has my Hotel res. for 4 months now ha ha
Kyle
Kyle
Not sure what info you want.
4.005 bore X 4.00 stroke
Mahle custom piston made for us
Customer supplied LS1 callies rods
Callies crank
W2W girdle system on mains
Aluminum LS1 heads (customer supplied)
Comp R lifters
Cam Motion hyd roller
Jesel adj rockers
ls6 intake
Ported F car throttlebody
160 lb hr injectors
Big stuff 3 controller (this is highest HP coil on plug we have ever done)
Truck coils
W2W ported oil pump
Dailly scavenge pump
ARE 2 stage drysump pan
Garrett 88-98mm turbo
Honeywell air to water intercooler
The pricing on these engines is per customer requirements. I don't have a blanket price.
Kurt
Callies crank
Comp R lifters
Jesel adj rockers
ls6 intake
160 lb hr injectors
Truck coils
W2W ported oil pump
Kurt
I forgot to mention the stock pick up truck ex manifolds.LOL
Kurt
Kurt
Originally Posted by Nine Ball
1300 hp with an LS6 intake, F-body throttle body, hydraulic cam, and LS1 heads. Thats just insane!
My next drag car needs to be a single turbo setup.
