Sts Turbo Dyno #'s Inside*****UPDATE*****
Old Sep 22, 2004 | 08:37 PM
GONEB4U's Avatar
Default Sts Turbo Dyno #'s Inside*****UPDATE*****
Well I just got back from the dyno. We turned up the boost to 9# on the Methanol injection. The car ran great on the dyno with not even 1 deg. of knock retard.The timing was set at a conservative 13 deg.On 93 octane pump gas. This is a 2002 stock automatic WS6 Trans Am (only mod is a fuel pump and 42# inj.) Made 476.8 RWHP and 510.6 FT.LBS OF TORQUE. I think almost 200 rwhp over stock is not bad for a stock car with the base STS kit spraying methanol.I'll try to get the dyno graph up asap.
Old Sep 22, 2004 | 08:39 PM
goober35's Avatar
NIce man. Where are u located. I want to run you when i get my set up done. Should be around Xmass
CHRISPY's Avatar
awesome results!!! That timing is REALLY LOW BTW but should be very safe
with the methonal you could probably get away with a bit more timing but I wouldnt push it with the nice numbers you have there
Old Sep 22, 2004 | 08:42 PM
GONEB4U's Avatar
The car is located in Connecticut. Thanks for the support guys.Goober35 maybe we can meet half way.
Old Sep 22, 2004 | 09:11 PM
blue-ss-camaro's Avatar
do you have any computer stuff done? if so who did the tune?
Old Sep 22, 2004 | 09:13 PM
goober35's Avatar
LOL i dont think so. Guess we will be racing times.
Old Sep 22, 2004 | 09:29 PM
GONEB4U's Avatar
Yes. The stock computer was tuned at Eastside Performance via ls1 edit.
Old Sep 22, 2004 | 10:02 PM
Unusual T/A's Avatar
I'll run you.
Old Sep 22, 2004 | 10:58 PM
goober35's Avatar
When will your car be done. I have not heard any updates. U still have the stock bottom end.
Old Sep 22, 2004 | 11:06 PM
I am beyond stock. Send me a pm for more info I don't want to ruin this guys thread.
Nice number btw to the original poster!
Old Sep 23, 2004 | 12:26 AM
Blackbird's Avatar
nice- did you try to bring up the timing and get KR? or did they start conservative and you were happy with the numbers so said leave it???
Old Sep 23, 2004 | 06:41 AM
scottywheels's Avatar
it was left safe, its on aq stock motor tuned by NOGO at eastside. the car is far from the edge, thats where it should be.. iLL tell you i saw it dyno and man that car is nice sounding......
Old Sep 23, 2004 | 06:57 AM
what number on the wide band are you running. I am running 9.9 to 10.5? is that to rich?
Old Sep 23, 2004 | 07:15 AM
Angus's Avatar
Did you dyno the car stock? What were the numbers?
I am glad to see that this lit is doing well and anticipate the day I get mine on. I am not looking for a race car and have always wanted a boosted car. I think this kit is the best bang for the buck to add some fun to drive boost on my car with no hassles. Right now I have a (see sig) with a GM crate LS6 engine and a 2800 vigilante stall and it dyno's over 320 with no tune done (motor just thown in) and can run 8.0 in the 1/8 on slicks. I think my car will be able to run pretty good with that kit on it.
Old Sep 23, 2004 | 07:54 AM
NOSjohn's Avatar
Restricted User
What size turbo?
Old Sep 23, 2004 | 08:14 AM
GONEB4U's Avatar
We tried 14 deg but the horspower was the same because the motor was already heatsoaked at that point.So we left the timing at 13 deg to be safe. Usually a car will load up harder on the street or strip then on a dyno.So to prevent knock when driving it hard we felt that 13 deg was this cars sweet spot.We kept our a/f in the 11-12 range.9.5-10.5 is a little rich.We never dynoed this car but Eastside has dynoed tons of cars. What they usually see on for rwhp on stock 2002 F-bodies range between 280-low 300's rwhp stock on the automatics. The turbo size is 60-1.
Old Sep 23, 2004 | 08:51 AM
Parker TX's Avatar
how much power can you get out of a built LT4 with these kits?
Old Sep 23, 2004 | 09:04 AM
GONEB4U's Avatar
It all depends on your tune and turbo size and of course how built is your motor. With the base kit 60-1 it's able to make in the 600 hp range at the crank. Now if you were looking for more than a larger turbo would be needed. For example a 76 turbo should be able to make around 1000hp at the crank.It all depends on the combo.
Old Sep 23, 2004 | 09:29 AM
Blackbird's Avatar
that's excellent. I am really hyped to see what my 6 speed car with the gt67 @ 10psi with front mount and alky is gonna do now
500 should be cake.
Old Sep 23, 2004 | 01:43 PM
CHRISPY's Avatar
Kevin is a tuning guru. Those numbers are fantastic
Cant wait to hear track times!
