Blower guys: Who is running more than 7 lbs on stock bottom end?
I want to pulley down to a 2.75 pulley to get my 9 lbs which my kit is rated for, right now I push 7 and that is basically right at redline for the most part its at 5 lbs until the last 1000 rpm
Just wanted to know who is and who has been running 9 lbs of boost safely on the stock bottom ends.
Thanks!
Thanks!
Blown WS-6
Originally Posted by Got Me SOM
10-12 lbs? that would make me kinda nervous even with a 11:1 a/f tune.
I'll pulley down to get my 9 lbs that should hold me over enough for now.
you could always stick a water injection kit on there to be safe. dont forget, the smaller the charger the more temp it will put in the air at the same boost. check the flow graphs to make sure your not over reving the impeller. if you are inlet temps will rocket, and det will accur much sooner!
hope it all goes well. thanks Chris.
I'm hitting 11 - 11.5 lbs of boost when I rev to 6200 - 6250 with the nice cool fall air. This is with a D1SC, 4.5 pulley, and a SIC. Note I'm also running a 93 + Torco mix on top of a conservative tune for added safety.
Mark
Mark
i am running 8-8.5 psi (turbo)right now no problem car is slow as ***** though still cant figure it out. hold boost just makes no power. If i ever get it running right boost will go to 10-12psi with the quickness.
when you guys pullied down, did you retune or did you just swap it out and go from there?
That right there is what is going to get you into trouble...... and then you will be when the bottom end goes Retunbe EVERY time you add more boost because timing will have to be changes and well as more fuel to go with the more air. If you dont your asking for nothing but trouble.
I know ive doen it..... do a search under my screen name and see how those stock pistons liked 11 psi with a tune for 7 psi.
Kyle
ditto.
the one main drawback about the stock ls1 computer is when you add more air, load doesn't automatically increase, pulling timing and add fuel, like the ford eec's work
Ryan
Ryan
Kyle
Kyle
I just want to crack the 500 rwhp barrier in my a4.
Now watch out for the A4 ..... rebuilt mine twie aqnd this time it lasted 2700 miles... they just cant take the HP.
