SD CONCEPTS support bracket
Old Nov 1, 2004 | 07:46 PM
99fireredls1's Avatar
Default SD CONCEPTS support bracket
I have installed the sd concepts 8 rib setup. It took a long time, but should be worth it. My question is where does the support bracket go that connects to the oil pan? Can someone decribe where it attaches or maybe a pic of where it goes? I checked the webpage and the pictures will not pull up.
Thanks.
Old Nov 1, 2004 | 07:53 PM
frcefed98's Avatar
Yep right too the corner of the oilpan(driverside front of the pan). There is a threaded hole that it will bolt right up too(the flat side of the bracket goes to the pan) I'll see if I have any pics here on the HD, but you should be able to spot it now.
Old Nov 1, 2004 | 08:09 PM
Default pics
ok the flatside. The side with the smaller hole goes to the front driverside of the pan. A pic would be great.
Old Nov 1, 2004 | 08:21 PM
frcefed98's Avatar
Hope this helps Its the only one I have saved to the HD right now...
J
Old Nov 1, 2004 | 08:28 PM
NA$TY-TA's Avatar
J
Jer whats that braided line going by the blower belt???
Old Nov 1, 2004 | 08:32 PM
frcefed98's Avatar
What braided line?????? I see no braided line in said picture???
thats from my old TNT dry kit a few months back. I still getting some odds and ends for my new wet kit
now back on topic
Old Nov 1, 2004 | 08:53 PM
Thank you pic helped. OHHH that little braided line... I wouldnt worry about that little line. lol
Old Nov 1, 2004 | 09:20 PM
frcefed98's Avatar
on the supertrooper adlib
Old Nov 1, 2004 | 10:24 PM
Billy the Great's Avatar
this setup rules. the belt that has been on bos's car is the original one he put in when he istalled it over the summer. And he hasnt been nice to that belt either. it has endured though many dyno pulls and a few track passes and then some more pulls with the new setup. if i was to ever build a blower setup i would only use the sdce setup. to bad i prefer beltless boost
