Intercooler question
Old Nov 5, 2004 | 11:00 PM
Armageddon's Avatar
...with cheese.
Default Intercooler question
I'm working on an OBX rig... My question is, when I get it all mounted like I want it, and I get all the piping right. Can I let the turbo blow through the piping and intercooler to blow out any "trash" that might have gotten into the works? Would it hurt anything to have the turbo blowing into the atmosphere and not into the intake. Keep in mind I would have a filter on the tbody the whole time. It's just the turbo blowing through all the piping and the intercooler into the atmosphere where it would normally be pushing air into the motor... Just a thought I've had in my head. Better safe then sorry.
Old Nov 6, 2004 | 12:21 AM
EightBall's Avatar
I was thinking the exact same thing. I dont see any harm in it...
Old Nov 6, 2004 | 12:45 AM
F8L Z71's Avatar
12 Second Truck Club
As long as you're not reving it at 7K you should be fine..
When my IC got filled with water I was trying to run it open to blow out the water. It doesn't work really well though with water as there is no real load on the turbo so not as much air gets pushed through. I would try using a compressor and air hose too. That might push some of the larger pieces of crud out easier.
Old Nov 6, 2004 | 12:51 AM
Armageddon's Avatar
...with cheese.
thx for the replies
Old Nov 9, 2004 | 03:47 PM
mkoch1's Avatar
that's not a good idea. Your wastegate will stay closed until the manifold see X amount of boost. Since your turbo is not connected the motor will keep spinning the turbo faster and faster. I am not sure if it's possible but you may overspin your turbo.
mark
Old Nov 9, 2004 | 05:02 PM
1point3liter's Avatar
it is possible.
Old Nov 9, 2004 | 06:16 PM
EightBall's Avatar
mark
I've never seen a car spool a turbo to full boost while revving the engine sitting still unless they were bouncing it off of the rev limiter or 2-step
Old Nov 9, 2004 | 06:57 PM
slyws6's Avatar
You will be fine, there's no load on the engine to spool up the turbo that fast. Just take it up to 3-4k rpms at most.
-Sly
