STS Meth system is screwing up? HELP please!
I just figured out that my Meth system is spraying meth everythime the car builds boost. Even like 3lbs of boost! The Only way I could get it to stop was to Pull the fuse for the system/? Its comming on without powering it up (with the fuse in place)? Have any of you got any ideas why this might be happening? I fallowed the instructions to the tee and I did all the system checks they said to do. I even put in a few of the optional indicator light that show when you have Low pressure and when the pump is comming on.
I was able to run the car WOT for the first time justa few minuts ago after I pulled the fuse.
I dont know what to do from this point so if any of you got an Idea please let me hear it!
Please tell me what you think? Lata, Ark
If you look at my graphs on my rice etr page, you can see my afr dropped well below 10:1 but the car never bogged and power didn't drop.
My system is set up with a presure switch which has not bin adjusted from its stock setting. Just as the STS instructions say, The system is hooked up to the Boost controler power line. Its Not meant to come on unless I power/Arm the system which in turn switches me to high boost and activated the meth system. Once it switched on then the meth should start spraying at the same time the boost comes on and activated the pressure switch. (At least this is how I understood it to work?).
ALSO once the Meth starts spraying the car falls flat on its face! It starts braking up bad!
Let me know if I am not making cence?
AS for the Meth. That was with only 3 lbs of boost. That's not my LOW boost setting. I had to change the spring and move the 1/4 fitting on the Compressor housing to get it working correctly BUT now with the new spring and the fitting in the correct spot I am getting 8lbs on LOW boost. I may have to drop down one spring size as I was shooting for 7PSI on low. I have 8.5 to 1 comp. so we will see how this acts for a little while? I think the Meth might be OK with this Higher level of boost.
Thanks for the help. I do appreciate the replies and the ideas. It helps a LOT to be able to get other opinions on what's Going on. Lata, Ark
