Better to lower CR with pistons or heads?
I am looking at going with a stock cubed forged shortblock right around 9:1 compression. Will more than likely be buying the AP shortblock. The two ways to go are with LQ9 or AFR big CC heads which will put me around 9:2 or so for CR or to go with the 205 AFR heads and use dished pistons to lower the CR.
Can anyone explain which would be the better choice and why? I am looking for maybe 750-800 rwhp on a twin turbo setup max with 98% of the driving done around 500-600 hp level. Not trying to set any records here. TIA
http://diamondracing.net/excel/gm/sb...shapeddish.htm
http://diamondracing.net/excel/gm/ls1strtstripdish.htm
Is one way better than the other or does it matter at all? Are there any issues with screwing up the quench area or anything else?
