Fuel Injection Management for 20+/- PSI
Old Feb 11, 2005 | 09:03 AM
DAPSUPRSLO's Avatar
Default Fuel Injection Management for 20+/- PSI
What are you big boost guys using for fuel and ignition control? I wouldn't think you are running the ls1 pcm only. Are you running a piggy back or stand alone? What types have you had success with and have good ease of tunability? Somewhat cost effective is deffinately a good thing. The maf sensor is not being used right or does it offer benefits in this kind of situation? What kind of Map sensor are you guys using?
This car will have a low boost 93 octane street mode as well as a high boost 116 or so octane high boost mode. I would imagine I could make two different settings just like ls1 edit and load them into the setup when I decide to run either high or low boost.
Thanks for the help.
Old Feb 11, 2005 | 11:43 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
-21 psi
-GM 3 bar map sensor added
-GM truck coils
-MSD truck wires
-C16 tune
Old Feb 11, 2005 | 12:37 PM
DAPSUPRSLO's Avatar
-21 psi
-GM truck coils
-MSD truck wires
-C16 tune
Are you using the stock pcm with the 3 bar sensor? I take it no MAF sensor? Why the truck coils? Thanks
Old Feb 11, 2005 | 12:45 PM
Boostaholic's Avatar
BigStuff3 here, lots are using Gen7 and FAST
Old Feb 11, 2005 | 01:04 PM
DAPSUPRSLO's Avatar
Stand alone or just for fueling with the Cartek adapter.
Old Feb 11, 2005 | 01:08 PM
LS1Tech Co-Founder
-BS3
-21 psi
-GM truck coils
-MSD truck wires
-C16 tune
Old Feb 11, 2005 | 01:17 PM
Standalone, autometer gauges with custom dash in progress.
Old Feb 11, 2005 | 01:25 PM
Hardcore Gary's Avatar
Big Stuff on the Hardcore cars. Has more data gathering capability than the Fast stuff.
Old Feb 11, 2005 | 01:35 PM
DAPSUPRSLO's Avatar
-BS3
-21 psi
-GM truck coils
-MSD truck wires
-C16 tune
Yeah, I missed the BS3. Thanks for all the input guys.
Old Feb 11, 2005 | 01:41 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
BS3 here!
Old Feb 11, 2005 | 02:27 PM
NA$TY-TA's Avatar
BS3 here also with a custom dash with all Autometer gauges........
Kyle
Old Feb 11, 2005 | 02:30 PM
DAPSUPRSLO's Avatar
Originally Posted by Chris@AP-Engineering
BS3 here!
It seems that BS3 is the way to go. He Chris I sent Nick a pm with some questions. I send it over to you as well. Thanks.
