650-750rwhp folks - air filter?
I finally got my filter made by K&N had to wait about 2 months... fit with nothing to spare, 5" inlet, 7" OD, 6" long cone ![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
here is some pics someone took of the car last weekend at a meet:
cant see it too well... but its stuffed in there.
If the car wasn't a daily driver I woudln't even bother with a filter....
![](https://www.cheesefrog.com/albums/album69/carshoot_53.sized.jpg)
LS1Tech Co-Founder
The one I have now is just for moving the car around, it's not rated for power level. We have dynoed the car with it off.
I have a 4.00 inlet, 6.00 base, 5.00 top, tapered, 8.00 long filter I am going to try to fit. I eventually will try it at the track and see if it affects the performance.
How much did K&N charge you to make a filter to your specs?? who do you contact there??
Thanks
Kyle
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Air filter flow is all about surface area. Those HKS mushroom filters are worth donkey ****, we lost 40 rwhp on a friends TT car using 2 of those filters. As a side effect, after a while the foam starts to break apart and get sucked into the turbo/blower.
I'm running a 10" long K&N with a 4" inlet, it flows nicely for my setup.
I ruin the end of films...
Here ya go John. This is the only way I could get a filter on my setup since the turbos are so close to the charge pipe...
http://www.turbomustangs.com/forums/...threadid=34357
http://www.quarter-mile.net/images/turbo/filter/
I'll get pics of mine this weekend.
Not sure about street driving. If it's not mounted low, you could probably get by. I'm thinking about taking mine apart and adding a piece of panty hose or thin filter element between two layers of screen. That would help cut down on dirt.
6 Second Club Moderator
I would be curious as to your:
-filter size(s)
-rwhp/rwtq
-Any testing you have done with air filter size
-filter size(s)
-rwhp/rwtq
LS1Tech Co-Founder
Something like that will keep out the bigger debris. Most race cars dont run filters, ie. look at cars like Moran's Monte Carlo. For the street a real filter is kind of nice.
Andy, I know that, but I have actually called up KN and SB and talked about the cfm rating of various filters that I could order.
