T-Trim and YSi-Trim peepz holla!
Do Baby G-trims plus the bottle count?
Maybe 750.
Built th400 and 4000 stall going in next week John.
I'll finally have the parts needed to run this hunk of scrap with a bit more power..
Steve
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Steve
Sure do!
I've seen a few local deals for T-Trims Steve, like for $1100.
Are you running an intercooler?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yes I have one of them OBX units made by little elves in a hollow tree.. Works FANTASTIC! Pics in sig.
10 & 11 Second Club
I`m not so much shooting for a certain HP #, but I am looking for 9.5s or maybe even 9.2s. I`ve only made 7 runs with the Ttrim setup and the car only hooked on 1 of those runs and bounced off the rev limiter from 1000' to the traps. I`m using 28" slicks instead of 26", tightening up the converter from PT4400 to 3800 and a set of AFR 225s this year.
LS1Tech Co-Founder
I have about 6 passes with the YS stuff and had belt slippage on every run. I lost the belt on most of passes. Since then I added a custom strut brace which should make a nice difference at the track. If I have more belt problems I might source a high flanged tensioner pulley. My goal is 8.99 I.. I mean 9.99.
Is your T-Trim pretty quiet? Got pics?
No pics. Looks like an S-Trim except a larger inlet.
It's an SQ Hybrid T-Trim. Just a bit more whistle than an SQ S-Trim. You can only hear it when you have another object like a wall or car opposite the front wheel well openings. It's just loud enough that people ask if I have a blower. Sounds good tho. Not obnoxious.
The .25" flanged pulleys Lee @ ASP made for me had another advantage. He makes the side flanges come in with a V shape which seems to really grab the belt nice like a glove. Think it may have picked up .5psi with the increased grip.
I believe laser or however bracket/pulley alignment with shims is def #1, but after that the flanges can help as a crutch before you move into crazy/complicated tensioner solutions. You could also increase tension maybe with a slightly larger pulley in one area (preferrably one that doesn't move, ie: not tensioner pulley).
We started with a Katech adjustable tensioner but found that a stock C5 tensioner was better. It's not too hard to fab up a tensioner. You just need to make a custom bracket, etc. Grab one of these to play with (cheap) -> Dayco Truck Tensioner P/N 89222.
Which pulleys are giving u a headache?
8-Rib?
Maxed out the MAF again today throwing a P0101.
Had to bump up from 28000 to 32000MHz.
P.S. Don't knock the Gates Laser alignment tool. It's a nice sanity check and not that expensive.
im shooting for 600RWHP on pumpgas with my 306 with around 14-15lbs of boost, and a small shot with the tiny little S-trim (made 530+ with old blower @ 8lbs + 50shpt). We make over 1200hp with the company car which has an X-trim on it
Are you intercooled?
Fuel Pump/Injector limited?
10 & 11 Second Club
Originally Posted by MelloYellow
At 570rwhp there is more left in your T-Trim for sure.
![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Originally Posted by Fryguy302
I ran a t-trim on my mustang last year. Even just with the 8 rib it went deep into the 9's. That's an underated blower.
What was your race weight?
My winter project is complete. I dumped my problematic C5 Vortech kit and switched to the RMCR C5 kit. I also upgraded from an S-Trim to a T-Trim head unit at the same time. I also added AFR 205s and a 220/224 115 Comp cam.
I need to hook the wideband back up and dial in the WOT AFR. It is slightly lean right now. I don't know when I will make it to the dyno to get numbers (the nearest one is an hour+ away).
With the heads/cam/new blower I am seeing 7.5 psi at my home altitude of 7000 feet. I don't want any more than that right now since I am still running the stock bottom end.
I am hoping to see 120 in the quarter (altitude 4900 feet) but we'll see what reality is.
The altitude here eats ~25%+ of my power so my numbers will be pretty weak compared to everyone else's.
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
