Overboost = 906rwhp/975rwtq
any ways Dave, how come the RPMs didnt scan, id like to see that.
where were your IAT at?
and next time keep it over 23psi, i thought youd be shooting for 1000+rwhp
congrats awsome numbers
sounds like your going to be needing a parachute to keep it leagal now!
Dave how long does the methanol last?
the methanol.. i probably used $1 worth on the 4 pulls i did total. it only runs when i'm above 5# boost. i think its very street since its the main component in windsheild washer fluid and i have it in my windsheild washer tank. i probably run a gallon through it every other week.. an extra $5 isnt too much to ask I dont think. *edit* i have a low level sensor installed in the tank so i know when its close to running out via red led.
i was telling the guys there i was just planning on getting the tune secure... and it was fine w/ my street tuning so i bumped it up to the next set point.. which was not what i thought i set it at.
i'm in richmond va.
intmd8.. does your volt booster hold over 15v for the entire time? either my alternator cant handle it or i have another issue
i'll find out how fast it will be next sat.
the rpm where it hit overboost control was about 4800
the other pulls it was over 800rwhp from 4600 to 6200 rpm but i have to say it is still peaking earlier than i want... maybe intake or tb or heads restriction?
It's designed so you don't have to run race gas all the time. If I were to build a full on race car I wouldn't even bother with methanol unless it was methanol only and no gas. LOL
http://www.automotivelifestyle.com/g...5/MVC-264F.JPG
http://www.automotivelifestyle.com/g...5/MVC-256F.JPG
http://www.automotivelifestyle.com/g...5/MVC-266F.JPG
http://www.automotivelifestyle.com/g...5/MVC-257F.JPG
http://www.automotivelifestyle.com/g...ies/mouse1.MPG
http://www.automotivelifestyle.com/g...ies/mouse2.MPG
i have 96#'s in and they went to 83% on one run because i was so rich. it may have been fuel pressure related since my voltage was down. but i can put some 160's in if necessary.. but dont plan on it.
STS guys
Please.......
Dave, you using tghe E-boost to switch on the meth? How much meth do you estimate you are using? Before I added my FMIC I used almost half a gallon on a 2hr trip home when I was playing with the turbo the first night I got it. After the FMIC it took me 2mos to use the same amount. Just wondering if I'll be back to dumping it in after my new combo is finished. LOL
