Anybody here running a CoolingMist system?
Old Mar 28, 2005 | 08:41 AM
Ryan K's Avatar
Pathological Modifier
Default Anybody here running a CoolingMist system?
Is anybody running the water/meth kit from Coolingmist? Just looking for less expensive alternatives....
Ryan K.
Old Mar 28, 2005 | 11:39 AM
Blackbird's Avatar
u want less expensive, build your own.
will cost you under $100
Old Mar 28, 2005 | 01:52 PM
Silver02Z28's Avatar
I'm building my own using a ShurFlo pump, pressure switch and a nitrous nozzle and jet I have lying around in the garage. Does anyone know if 100 psi through a nitrous jet will work?
Old Mar 28, 2005 | 05:33 PM
Ryan K's Avatar
You're not going to get a good atomizeation with the nitrous nozzle.
Old Mar 29, 2005 | 12:06 AM
BudH's Avatar
I'm running a Be Cool system from Aquastealth!
http://www.aquastealth.com/index.asp...S&Category=212
or
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Not a bad setup for a basic system! I'm using my windshield washer tank to hold the alcohol!
Old Mar 29, 2005 | 02:15 PM
MY99TAWS6's Avatar
I got one for my 97 talon but haven't installed it yet.Dual stage one before the intercooler and one after.
I am not sure they are quite as good as the ones like sts or forget that other one that thinks uses electronic adjustabilty.
Old Mar 29, 2005 | 02:24 PM
Ryan K's Avatar
I have heard that its not a great idea to run them before an intercooler. I hear that the water can condence and pool in the intercooler. But hey thats just what I read. I plan on running two nozzles after the intercooler.
Also I am going to mount the tank in the spare tire well. Much cleaner under the hood and you can run a larger tank.
Ryan
Old Mar 29, 2005 | 02:29 PM
SUPER DAVES Z's Avatar
Hey Ryan,
I picked up a used SMC from turbobuick forums for $175 shipped. Just make sure, if you go with the SMC kit, you get the one with the square bottle. The round one is not compatible with meth. I liked it a lot and was able to run 13 psi with the same tune, on pump with your TTi kit.
Later,
Dave
Old Mar 30, 2005 | 08:58 AM
kcshaner's Avatar
Originally Posted by SUPER DAVES Z
Hey Ryan,
Later,
Dave
Do you have a pic of your bottle? I want to make sure mine is the right one. Thanks.
